Tori, you might want to try this "There are two ways to access Roxio BackOn Track to recovery the computer, either through the boot menu, or through the Windows Start menu.
Access Roxio BackOn Track using the boot menu if computer cannot access Windows.
You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored.
Press the power button to turn on the HP Mini.
Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.
Access Roxio BackOn Track using the Windows Start menu if computer can boot into Windows.
If you can access Windows, in addition to restoring your computer to a previous working state, you use other options, such as Disaster Recovery.
Click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track." more information about that on here. Hope this helps, good luck.
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
