Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
A single touch line is not working anymore.
Hi,
I just had to replace my damaged LCD display and after replacing it a single touch line is not working anymore.
It the last app line before the dock or in the calculator the line with the numbers 4,5,6 and the +.
Do I have to replace the whole touch?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Matthias, it is my experience that if part of the digitizer does not work, the whole digitizer needs to be replaced. Of course, since you just worked on your phone, I would recommend that you double check your work first. IF you find that all connections are properly seated and all your cables are okay, it is time to replace the digitizer. I also would recommend to replace the front panel assembly, since it is a lot easier, quicker and less likely to fail. Here is the guide and the part is available right here, as well as many other places. Hope this helps, good luck.
Punteggio 2
2 Commenti:
Thank you for your answer. It's not the first iPhone I'm reparing but first time something like this happens.
I double checked all connections and just saw that the cable (touch) is a little bit damaged. So I have to replace it a well.
Thank you!
da
Sure looks that way :-) best of luck to you.....
da
Aggiungi la tua risposta
Matthias sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 527
