Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
3GS turns off at ~60%
My 3GS turns off at appx. 60 % - Will power on again only when charger connected.
In diagnose log following error is displayed:
Reset count:0
Boot failure count:1
Boot faults: rst vdd_under
Boot stage: 80
Boot app: 0
Is this causer by bad battery or?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
3 Risposte
Risposta Più Utile
I have changed many batterys that die at higher percentages than you would think. Best solution is to purchase a battery and follow the guide here on ifixit to install, or find someone who can help you out. This will resolve your issue 99/100 times.
Punteggio 1
This would in fact be the cause of a bad battery.
Punteggio 0
Same problem for me with my iphone 4, but just reset or keep the screen black until push the on/off button to turn on but not ask for pin code....:
Diagnose log error:
Reset count:0
Boot stage: 255
Boot app: 0
Is this causer by bad battery too?
Thanks in advance.
Punteggio 0
Aggiungi la tua risposta
reenee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,332
