Salta al contenuto principale
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
computer not logging on at all
Screen does not come up with log in but comes up with a folder with a ? in it
Questa è una buona domanda?
Punteggio -1
1 Commento
If you've dropped or bumped your laptop you may have disconnected the HD. Use the guide to check that the HD is firmly seated in it's slot.
Good Luck,
N.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
harddisk failure ?
when the hdd is not connected - or defective - it shows the ? on the screen
Punteggio 0
What the folder with flashing ? means is your computer can't find the startup disk. Usually this indicates a bad drive. To try to fix this, hold down option while booting, and see if you can boot from your drive. If you cannot, then your drive is fried. If your data is not backed up then you can recover some of it with tools such as Data Rescue. It's a good tool well worth the $99.
If you can in fact boot to your drive, immediately backup all your data before it disappears.
After this, you'll need to buy and install a new drive. Instructions are here.
Punteggio 0
Aggiungi la tua risposta
Claire sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,038
