Why would a "brand new" battery only last for 6 cycles?
I recently purchased a battery for my macbook pro that was sold and priced as new. Once I had it installed it would only charge intermittently and since I had wrung the rest of the hardware out already I decided to take a closer look at the "new" battery and something odd caught my eye. The bar code giving the S/N had been purposely vandalized so it could not be read. I contacted the company and was assured it was new and the wiped UPC was due to some story involving the supplier making sure no one but them got the batteries.... yeah okay. Now if I had gone to Apple, for only $10 more plus tax + shipping I would have received a brand new battery (with legible S/N I'm sure) that they install with a warranty twice as long as the 6 mod I was given. Fast forward 4 mos give or take and my discount oem new battery won't hold a charge and the cycle count is at 6. 6? That doesn't sound like new at all, in fact I feel like I have been defrauded by a company that most consider reputable. ANy ideas on what I should do next and what is thought of any responsibility I may have to my fellow man to do everything I can to make sure folks are aware? And do I need to worry about potential damage caused by this battery?
Questa è una buona domanda?
2 Commenti
Ok, all good advice but upon contact the company had a replacement sent out in a day and I now have it installed, but here's the thing. The a/c adapter is showing amber as if its charging, the system report says its charging, and coconut says its charging but the ^##$ thing is sitting on 4% and has for the last 2 hours so how can it be charging? It was plugged in so how did it even get to 4% in the first place when it arrived with 40%? I had to replace the keyboard and when the first battery acted up and the company I purchased the battery from balked at my accusation of something fishy I replaced the magsafe board as well, and I'm fairly certain it was new. Can this be some firmware issue due to it being disassembled for a time? I'm perplexed and quite frustrated. oh and just in case it helps The info from coconut is as follows:
Current Charge: 236 mAh
Max Charge: 5672
Current Cap: 5652
Design Cap: 5770
MacBook Pro 8,1
Age 10 mos
Loadcycles 0
Batt Temp 30.1 C
da Chari Chascarillo
Contact the vendor and ask them... the onboard circuitry of the battery, or the battery cells are the problem... all other components are reporting functional. DO NOT CONTINUE TO USE THE BATTERY... you could burn out one of the working components.
da originalmachead
