Salta al contenuto principale
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
need help Identifying my iPod
I have a 30gb 4th gen iPod model number A1099. Id like to know if its a photo or regualr iPod.
Questa è una buona domanda?
Punteggio 1
1 Commento
Out of curiosity, are you unable to turn it on? The easiest way to ID it is to check the screen. Additionally, the color LCD is more of a black color when off, compared to the gray, flat look of a monochrome LCD.
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
You have an iPod Photo. For future reference, we have a nifty little guide that can help you ID your iPod.
Punteggio 2
I believe your 30GB model is an iPod Photo. you can look up the model number on sites like this one
Also, according to wikipedia, the "regular" 4th gen iPod only came in 20GB and 40GB versions, so your 30GB one must be the "Photo" version
Punteggio 0
As the others have said, you have a photo, but a general fact you should know is it's not really necessary to know, almost all the parts are interchangeable between Photo and 4th gen.
Punteggio 0
1 Commento:
It's deceptively trickier than appears. The moving of the display connector on the logic board makes the display, logic board, and front panel not directly interchangeable.
da
Aggiungi la tua risposta
Robert sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 2,453
