Salta al contenuto principale
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150 Domande Visualizza tutte
Why my car wont start?
I had my fuel pump replaced my car ran four 4 days and now it won't start back up. It acts like it wants to but it won't kick over.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Risposta Più Utile
Not knowing what you have tried and assuming you don't have the security light flashing...
Check your fuse block and verify it's not blown. Verify you have fuel pressure (50 -60 psi) should which remains constant for a period of time after the power has been removed. If you do not have the pressure its probably the pump. If you have fuel pressure, but is doen't hold, check the fuel pressure regulator.
Was the fuel filter replaced when the fuel pump was replaced?
Punteggio 2
I thought it wasn't a good idea to pump the gas pedal on a fuel injected system??
Punteggio 0
If you live anywhere that would have gotten gasoline from BP's Whiting refinery, you might have a case of bad gas from them. And it won't matter if you didn't buy gas from a BP station, as many stations will source fuel from other people. Our truck did the same thing, have you tried giving it some gas as you were cranking it? usually that will cause mine to fire up, but then you gotta kind of keep the revs up if it turns over.
Punteggio -1
Aggiungi la tua risposta
jesse sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,069
