Salta al contenuto principale
Modelli MacBook Pro con schermo da 15"
8253 Domande Visualizza tutte
Domanda Chiusa
What part of the screen is causing this problem?
My son brought my old laptop to his cousin's house (not in a laptop bag mind you). He doesn't remember dropping it but now the screen is doing this:
http://flic.kr/p/d2WLyd
Opening and closing the screen doesn't change the pattern (trying to rule out a loose wire).
Thoughts?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
This issue is a damaged LCD display. Below is the guide to replacing the LCD display (Assuming your Macbook Pro is a Pre-Unibody model judging by the picture)
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 LCD Panel Replacement
Hope this helps,
Punteggio 1
1 Commento:
Thanks, new LCD on order!
da
Risposta Più Utile
I dont think that a loose wire would have that effect. That seems to be a cracked screen.
Punteggio 1
3 Commenti:
The LCD looks perfectly normal when off. Cracked from the inside?
da
One of the layers of the lcd screen is most likely cracked. I just searched MBP cracked screen and the images returned look a lot like the issue you have, eg.
http://www.daytonanetworks.com/wp-conten...
da
If you want to make sure that the issue is not GPU, cables or connections related, hook it to an external screen.
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 9
Tutti i Tempi: 388
