Salta al contenuto principale
2.26 or 2.4 GHz / White plastic unibody enclosure
645 Domande Visualizza tutte
Domanda Chiusa
LCD replacing, various types?
My LCD screen starts to fade white while using my macbook, tilting the LCD helps the screen. At first I thought it was an issue with the LVDS cable but turns out after changing that out I still have the issue.
Now my sign points to LCD itself, I have hooked the macbook up to an external monitor and it was working fine. The mac itself does not freeze but is still fully functioning while the fading is occuring.
After looking at LCD screens on ebay, some list them as LCD, LED, and different type of backlight...
My question is what exactly is my screen? I have no idea what type of backlight it has. Also some ads state "no inverter" what exactly is the inverter part? The PCB board on the lower portion that the connector attaches to?
One last thing, why is there such a great variance between costs of these LCD screens? On here the screen is $130 while on ebay their between $50-$80??
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Your ID seems off I don't see any 2009 6,1 Macbooks, the 6,1's are mid 2010 - follow the ID your Mac to help us help you.
  • MacBook Pro "Core i5" 2.53 17" Mid-2010 MacBookPro6,1 1
  • MacBook Pro "Core i7" 2.66 17" Mid-2010 MacBookPro6,1 1
  • MacBook Pro "Core i7" 2.8 17" Mid-2010 MacBookPro6,1
With LED display technology, there is no inverter board. A single cable provides the data and power to the display.
Once you get the back off your display you'll find a manufacturers part number to help you locate a compatible replacement.
If this answer was helpful please remember to return and mark it Accepted.
Punteggio 1
6 Commenti:
Well its a Late 09 version Macbook, white with the rounded off edges (not square like the early 06 models). In the about for Mac when I do the machine details it shows 6,1.
Straight from Wiki.
Release date October 20, 2009
Model Numbers MC207*/A
Machine Model MacBook6,1
da
This is the actual unit 2.26 GHz (A1342) MacBook Unibody 13"
da
With that additional information I was able to find your machine, and it too has an LED display.
da
Thank you for the info.
What exactly would the inverter be on these things? Is that the PCB on the lower bottom where the LVDS cable connects to? I am coming across ADS on ebay that state "inverter not included".
Is there a difference between these ebay LCD screens and the $400 ones?
da
With LED display technology, there is no inverter board. A single cable provides the data and power to the display. 13.3" color widescreen TFT active-matrix LED-backlit "glossy" display with a 1280 by 800 native resolution.
da
Mostra 1 altro commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,004
