Salta al contenuto principale
Model A1001 or A1025 / 667, 800, 867, or 1.0 GHz G4 processor
50 Domande Visualizza tutte
Can I use a 800 mhz DVI logic board
I have a PowerBook G4 667 mhz DVI 15 inch with a bad logic board. Can I replace it with a 800 mhz DVI 15 inch logic board? are they interchangeable? Also, what about switching display assemblies from one to the other?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Yes, you can put a 800 MHz DVI board in a 667 MHz machine, but it is recommended to also install a secondary fan as well (the 667 MHz machines do not have the secondary fan). As for the displays, DVI displays are also interchangeable. You cannot, however use earlier Titanium model displays (Mercury or Onyx machines).
Good luck!
Punteggio 1
3 Commenti:
I knew you would know. Can he also go to the 1000 MHz board? +vote
da
yes! but he would need a different secondary fan.
da
Where does a Powerbook G4 Titanium DVI 867 secondary fan plug in?
Please reply to RHBernard@gmail.com of 203-984-2070
da
You may be in luck. There are four logic boards listed for the G4 Titanium. A 667, 800, 867 and a 1000. Ben Eiseman is the parts man around here. He should be able to tell you in the morning which ones will work. Here's the boards: http://www.ifixit.com/Mac-Parts/PowerBoo...
Punteggio 0
Aggiungi la tua risposta
robert owen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 838
