Introduzione
Replace the adhesive securing the front panel to the rear case of your iPad 2 Wi-Fi.
Before you begin peeling and sticking tape, it's important to have clean adhesion surfaces on both the front panel and the rear case. Use a spudger to scrape off any large excess bits of original adhesive, then clean all of the gluing surfaces with a paper towel and rubbing alcohol or Goof Off.
Throughout this procedure, it is recommended to peel up each adhesive strip as needed.
Carefully grasp the home button with a pair of tweezers. Gently lower and place the home button into the round opening located at the bottom of the front panel. The correct orientation of the home button is shown in the third picture. Make sure the back of the home button is face up and the flat portion of the inner home button circle is oriented to the top of the iPad.
  • Carefully grasp the home button with a pair of tweezers.
  • Gently lower and place the home button into the round opening located at the bottom of the front panel.
  • The correct orientation of the home button is shown in the third picture. Make sure the back of the home button is face up and the flat portion of the inner home button circle is oriented to the top of the iPad.
Aggiungi Commento
The two small notched trapezoidal strips will be used to attach the home button bracket to the front panel. Carefully peel off the first trapezoidal adhesive strip.
  • The two small notched trapezoidal strips will be used to attach the home button bracket to the front panel.
  • Carefully peel off the first trapezoidal adhesive strip.
Aggiungi Commento
Using a pair of tweezers, place the first trapezoidal adhesive strip (minding its correct orientation) on the matching side of the home button mounting bracket. Make sure to line up the profile of the strip with the edge of the mounting bracket.
  • Using a pair of tweezers, place the first trapezoidal adhesive strip (minding its correct orientation) on the matching side of the home button mounting bracket.
  • Make sure to line up the profile of the strip with the edge of the mounting bracket.
  • Repeat the procedure for the second trapezoidal adhesive strip.
Aggiungi Commento
Use a pair of tweezers to grasp the corner of one of the adhesive strips placed on the mounting bracket.
  • Use a pair of tweezers to grasp the corner of one of the adhesive strips placed on the mounting bracket.
  • Lift and peel the brown backing up off the adhesive strip, revealing the clear adhesive strip.
  • Repeat the procedure for the secondary adhesive strip.
Aggiungi Commento
Gently place the home button mounting bracket on top of the home button. Make sure the home button mounting bracket is lined up with the bottom of the digitizer.
  • Gently place the home button mounting bracket on top of the home button.
  • Make sure the home button mounting bracket is lined up with the bottom of the digitizer.
Make sure the home button mounting bracket has a parallel gap of 1-2 mm from the bottom of the digitizer. This will ensure that the mounting bracket makes contact with the home contact pins.
John - Replica
In the following steps, you will be placing the remaining pieces of adhesive on the front panel. Do not peel the brown backing off the strips just yet.
  • In the following steps, you will be placing the remaining pieces of adhesive on the front panel.
  • Do not peel the brown backing off the strips just yet.
  • Place the largest L-shaped adhesive strip on the top left corner of the front panel.
  • Smooth the strip down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
Aggiungi Commento
Place the thinnest L-shaped adhesive strip on the bottom left corner of the front panel. Place the thinnest L-shaped adhesive strip on the bottom left corner of the front panel.
  • Place the thinnest L-shaped adhesive strip on the bottom left corner of the front panel.
Aggiungi Commento
Place the remaining thin L-shaped adhesive strip on the top right corner of the front panel, near the camera mounting bracket. Place the remaining thin L-shaped adhesive strip on the top right corner of the front panel, near the camera mounting bracket.
  • Place the remaining thin L-shaped adhesive strip on the top right corner of the front panel, near the camera mounting bracket.
This is the third to last "L" shaped strip - it's the fatter one, without any diagonal cuts to it (used in the following steps)
Courtney - Replica
Place the straight adhesive strip on the right side of the front panel. If you've already attached the digitizer cable, you'll have to work around/under it to attach this strip.
  • Place the straight adhesive strip on the right side of the front panel.
    • If you've already attached the digitizer cable, you'll have to work around/under it to attach this strip.
Aggiungi Commento
Place the last L-shaped adhesive strip on the bottom right corner of the front panel. Place the last L-shaped adhesive strip on the bottom right corner of the front panel.
  • Place the last L-shaped adhesive strip on the bottom right corner of the front panel.
hi, i had my front panel connecting strip torn during repair… what can i do??
Shahzaib Qureshi - Replica
i had my ipad 2 front panel connecting strip torn down during repair…
plz tell me the solution
Lay the thin T-shaped adhesive strip between the bottom edge of the inner frame of the front panel and the camera mounting bracket. The longest edge should be flush with the inner frame. Lay the thin T-shaped adhesive strip between the bottom edge of the inner frame of the front panel and the camera mounting bracket. The longest edge should be flush with the inner frame.
  • Lay the thin T-shaped adhesive strip between the bottom edge of the inner frame of the front panel and the camera mounting bracket. The longest edge should be flush with the inner frame.
I believe this should go above the bracket. There is no metal to adhere to between the LCD and the camera.
Doug Hoderny - Replica
Yes, this is definitely the wrong way up. The adhesive strip should run along the outside edge on the screen.
giff - Replica
This image needs to be removed. Messed up a couple following this.
It is definitely upside down.
Deja Vu - Replica
This strip is upside down. I followed these instructions and the top of my digitizer is loose now and doesn't stay down in the bezel. I have to buy more strips and do everything over.
Tim Banks - Replica
No. Everything is showed correctly. This strip doesn't have to glue to metal, there are plastic spacers for it at the top of the LCD.
If you afraid the glass will be loose of the bezel then you can cut two thin stripes of another two sided tape and attach them to the bezel's plastic as an extra option.
KSE - Replica
Place the small hook-shaped adhesive strip below the left side of the home button mounting bracket. Place the small hook-shaped adhesive strip below the left side of the home button mounting bracket.
  • Place the small hook-shaped adhesive strip below the left side of the home button mounting bracket.
Aggiungi Commento
Lay the final small rectangular adhesive strip to the left of the hook-shaped adhesive strip, immediately to the right of the thin L-shaped strip, and flush with the bottom of the front panel. Lay the final small rectangular adhesive strip to the left of the hook-shaped adhesive strip, immediately to the right of the thin L-shaped strip, and flush with the bottom of the front panel.
  • Lay the final small rectangular adhesive strip to the left of the hook-shaped adhesive strip, immediately to the right of the thin L-shaped strip, and flush with the bottom of the front panel.
Aggiungi Commento
Make sure that each adhesive strip is placed in the correct location and orientation before peeling the backing. Peel the brown backing up off each adhesive strip.
  • Make sure that each adhesive strip is placed in the correct location and orientation before peeling the backing.
  • Peel the brown backing up off each adhesive strip.
  • Some of the adhesive strips are quite small and may require some patience to peel the backing.
Aggiungi Commento
Linea Traguardo
Altre 123 persone hanno completato questa guida.
Andrew Optimus Goldberg
Membro da: 17/10/2009
368.927 Reputazione
1.264 Guide realizzate
iFixit Membro di iFixit
Community
115 Membri
5.778 Guide realizzate
I think a straight on picture showing all the adhesive pieces in place would be really helpful.
patjmccarthy - Replica
How am i supposed to put the digitizer cable back, and how do i put the fron on it?
Haley Forbes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 107
Tutti i Tempi: 39,101
