Introduzione
Use this guide to remove the AC power adapter. For help troubleshooting click the link to our troubleshooting page iHome IH11 Troubleshooting.
Unscrew the two 9.0 mm screws with the Phillips #1.
  • Unscrew the two 9.0 mm screws with the Phillips #1.
  • Remove the translucent bottom plastic piece.
Aggiungi Commento
Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver. Repeat the previous step for the two 9.0mm screws on the bottom.
  • Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver.
  • Repeat the previous step for the two 9.0mm screws on the bottom.
  • Carefully slide the back cover off. There are wires attached to the back cover.
Aggiungi Commento
Remove the aluminum bracket by loosening the two nuts and removing the 8.0mm bolts with your hand.
  • Remove the aluminum bracket by loosening the two nuts and removing the 8.0mm bolts with your hand.
Aggiungi Commento
Remove the two 12.0mm screws that hold the motherboard with the Phillips #1 screwdriver. Slide the motherboard gently out.
  • Remove the two 12.0mm screws that hold the motherboard with the Phillips #1 screwdriver.
  • Slide the motherboard gently out.
Aggiungi Commento
Remove the two 9.0 mm screws with the Phillips #1 screwdriver, then slide the circuit board for the AC adapter out.
  • Remove the two 9.0 mm screws with the Phillips #1 screwdriver, then slide the circuit board for the AC adapter out.
  • Repeat the previous step by removing the two 9.0mm screws with the Phillips #1 screwdriver for the circuit board for the on/off switch.
Aggiungi Commento
Unsolder the main connections holding the AC adapter to the circuit board. Solder new adapter in same position with same connections.
  • Unsolder the main connections holding the AC adapter to the circuit board.
  • Solder new adapter in same position with same connections.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Nick Knowles
Membro da: 19/04/2013
9 Reputazione
2 Guide realizzate
Cal Poly, Team 14-9, Maness Spring 2013 Membro di Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 528
