Flip device over so the display is facing down.
  • Flip device over so the display is facing down.
Aggiungi Commento
Remove battery cover by pressing down on battery cover and sliding right.
  • Remove battery cover by pressing down on battery cover and sliding right.
Aggiungi Commento
Unscrew the two (2)  #00, 10 mm screws located below the microphones on the back cover.
  • Unscrew the two (2) #00, 10 mm screws located below the microphones on the back cover.
Aggiungi Commento
Remove the back cover (using a plastic removal tool around the edges if needed).
  • Remove the back cover (using a plastic removal tool around the edges if needed).
Aggiungi Commento
De-solder and remove the heat shield.
  • De-solder and remove the heat shield.
  • Be careful while removing this shield, since the copper sheet is very easy to rip
Aggiungi Commento
De-solder the line in port from its soldering points.
  • De-solder the line in port from its soldering points.
  • These points are located beneath the black shielding on the left side of the blue circuit board.
Aggiungi Commento
Replace Line-in port and re-solder at points specified in Step 6.
  • Replace Line-in port and re-solder at points specified in Step 6.
Aggiungi Commento
Reattach and re-solder the heat shielding back into place.
  • Reattach and re-solder the heat shielding back into place.
  • Again, be careful when soldering as it is very easy to melt through the heat shield and copper sheet beneath.
Aggiungi Commento
Conclusione
Alex
Membro da: 28/10/2013
731 Reputazione
5 Guide realizzate
Do you know what and where I can get the replacement part at all…?
phily2k1clegg - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 57
Tutti i Tempi: 2,050
