Salta al contenuto principale
Xbox Series X 2TB Galaxy Black Shell Replacement
Cosa ti serve
  1. Xbox Series X 2TB Galaxy Black Shell Replacement, Uncover the back panel screws: passo 1, immagine 1 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Uncover the back panel screws: passo 1, immagine 2 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Uncover the back panel screws: passo 1, immagine 3 di 3
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X 2TB Galaxy Black Shell Replacement: passo 2, immagine 1 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement: passo 2, immagine 2 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement: passo 2, immagine 3 di 3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of blunt tweezers to peel back the large sticker on the back panel to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the back panel screws: passo 3, immagine 1 di 2 Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the back panel screws: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $16.96
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Xbox Series X 2TB Galaxy Black Shell Replacement, Unclip the back panel: passo 4, immagine 1 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Unclip the back panel: passo 4, immagine 2 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Unclip the back panel: passo 4, immagine 3 di 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Xbox Series X 2TB Galaxy Black Shell Replacement: passo 5, immagine 1 di 2 Xbox Series X 2TB Galaxy Black Shell Replacement: passo 5, immagine 2 di 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the back panel: passo 6, immagine 1 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the back panel: passo 6, immagine 2 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the back panel: passo 6, immagine 3 di 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Xbox Series X 2TB Galaxy Black Shell Replacement: passo 7, immagine 1 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement: passo 7, immagine 2 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement: passo 7, immagine 3 di 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the fan screws: passo 8, immagine 1 di 1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
  9. Xbox Series X 2TB Galaxy Black Shell Replacement, Disconnect the fan cable: passo 9, immagine 1 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Disconnect the fan cable: passo 9, immagine 2 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Disconnect the fan cable: passo 9, immagine 3 di 3
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  10. Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the fan: passo 10, immagine 1 di 2 Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the fan: passo 10, immagine 2 di 2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
  11. Xbox Series X 2TB Galaxy Black Shell Replacement, Unlatch the base: passo 11, immagine 1 di 2 Xbox Series X 2TB Galaxy Black Shell Replacement, Unlatch the base: passo 11, immagine 2 di 2
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  12. Xbox Series X 2TB Galaxy Black Shell Replacement, Twist and remove the base: passo 12, immagine 1 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Twist and remove the base: passo 12, immagine 2 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Twist and remove the base: passo 12, immagine 3 di 3
    • With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
    • Remove the base.
    • During reassembly, put the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
  13. Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the optical drive screws: passo 13, immagine 1 di 2 Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the optical drive screws: passo 13, immagine 2 di 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  14. Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the vibration isolator: passo 14, immagine 1 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the vibration isolator: passo 14, immagine 2 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the vibration isolator: passo 14, immagine 3 di 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  15. Xbox Series X 2TB Galaxy Black Shell Replacement, Disconnect the power and data cables: passo 15, immagine 1 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Disconnect the power and data cables: passo 15, immagine 2 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Disconnect the power and data cables: passo 15, immagine 3 di 3
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
  16. Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the optical drive: passo 16, immagine 1 di 2 Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the optical drive: passo 16, immagine 2 di 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  17. Xbox Series X 2TB Galaxy Black Shell Replacement, Xbox Series X 2TB Galaxy Black Chassis Removal: passo 17, immagine 1 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Xbox Series X 2TB Galaxy Black Chassis Removal: passo 17, immagine 2 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Xbox Series X 2TB Galaxy Black Chassis Removal: passo 17, immagine 3 di 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  18. Xbox Series X 2TB Galaxy Black Shell Replacement: passo 18, immagine 1 di 2 Xbox Series X 2TB Galaxy Black Shell Replacement: passo 18, immagine 2 di 2
    • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • If the USB port cable feels adhered to the metal chassis, use an apply an iOpener or hair dryer to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
  19. Xbox Series X 2TB Galaxy Black Shell Replacement, Disconnect the power button cable: passo 19, immagine 1 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Disconnect the power button cable: passo 19, immagine 2 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Disconnect the power button cable: passo 19, immagine 3 di 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
  20. Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the chassis screws: passo 20, immagine 1 di 2 Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the chassis screws: passo 20, immagine 2 di 2
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  21. Xbox Series X 2TB Galaxy Black Shell Replacement: passo 21, immagine 1 di 2 Xbox Series X 2TB Galaxy Black Shell Replacement: passo 21, immagine 2 di 2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
    • Depending on your model of Xbox, the adhesive may be on the underside of the cable. If so, use an iOpener or hair dryer to heat the cable.
  22. Xbox Series X 2TB Galaxy Black Shell Replacement: passo 22, immagine 1 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement: passo 22, immagine 2 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement: passo 22, immagine 3 di 3
    • The center chassis assembly is aligned to the bottom of the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the chassis and pull it towards the top of the shell, uncoupling the guide pegs from the shell.
    • Use two hands to lift out the chassis to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
  23. Xbox Series X 2TB Galaxy Black Shell Replacement: passo 23, immagine 1 di 2 Xbox Series X 2TB Galaxy Black Shell Replacement: passo 23, immagine 2 di 2
    Dust Blower
    $5.99
    • Gently place the chassis heatsink-side down on a clean work surface.
    • During reassembly, this is a good point to clean the heatsink fins of any dust, dirt, or debris that may have built up over time. Use a dust blower or compressed air to clear out the fins.
  24. Xbox Series X 2TB Galaxy Black Shell Replacement, Separate the power button cable: passo 24, immagine 1 di 2 Xbox Series X 2TB Galaxy Black Shell Replacement, Separate the power button cable: passo 24, immagine 2 di 2
    • The power button cable is adhered to the shell with pieces of mild adhesive.
    • Use an iOpener or a hair dryer to heat the power button cable.
  25. Xbox Series X 2TB Galaxy Black Shell Replacement: passo 25, immagine 1 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement: passo 25, immagine 2 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement: passo 25, immagine 3 di 3
    iFixit Opening Picks (Set of 6)
    • Be very careful when lifting the cable where it connects to the board. Peel gently, and slide an opening pick under the cable if you're having trouble separating the adhesive.
    • Use your fingers to peel up the power button cable and fully separate it from the shell.
    • During reassembly, use thin double‑sided adhesive to secure the cable. If there's adhesive left and it's still sticky, you can reuse it. If you have a new cable, check it for pre‑installed adhesive and remove any liners.
  26. Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the power button board screws: passo 26, immagine 1 di 2 Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the power button board screws: passo 26, immagine 2 di 2
    • Use a T8 Torx driver to remove the four 5.5 mm‑long screws securing the power button board.
  27. Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the board: passo 27, immagine 1 di 1
    • Remove the power button board.
  28. Xbox Series X 2TB Galaxy Black Shell Replacement, Separate the USB board cable: passo 28, immagine 1 di 2 Xbox Series X 2TB Galaxy Black Shell Replacement, Separate the USB board cable: passo 28, immagine 2 di 2
    • The USB board cable is adhered to the shell with pieces of mild adhesive.
    • Use an iOpener or a hair dryer to heat the USB board cable.
  29. Xbox Series X 2TB Galaxy Black Shell Replacement: passo 29, immagine 1 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement: passo 29, immagine 2 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement: passo 29, immagine 3 di 3
    • Use your fingers to peel up the USB board cable and fully separate it from the shell.
  30. Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the USB enclosure screws: passo 30, immagine 1 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the USB enclosure screws: passo 30, immagine 2 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the USB enclosure screws: passo 30, immagine 3 di 3
    • Use a T8 Torx driver to remove the two 8.9 mm‑long screws securing the USB board enclosure:
    • One screw inside the shell
    • One screw on the bottom of the shell (where the base was)
  31. Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the USB enclosure: passo 31, immagine 1 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the USB enclosure: passo 31, immagine 2 di 3 Xbox Series X 2TB Galaxy Black Shell Replacement, Remove the USB enclosure: passo 31, immagine 3 di 3
    • Use your fingers to slide the USB board enclosure out from under the metal clip securing it to the shell.
    • Remove the enclosure.
    • During reassembly:
    • Make sure the Pair button is properly oriented and fully inserted in its slot.
    • Firmly slide the enclosure into position until it snaps into place under the metal clip.
  32. Xbox Series X 2TB Galaxy Black Shell Replacement, You're left with the shell: passo 32, immagine 1 di 1
    • You're left with the shell.
    • Compare your new replacement shell to the original—you may need to transfer remaining components or remove adhesive backings.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
Spencer Day
Membro da: 09/14/22
149.751 Reputazione
995 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.629 Guide realizzate
1Commento della guida
Does this come with the stand and the rear panel?
belokk - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 74
Tutti i Tempi: 1,183
