Introduzione
Use this guide to replace a broken or cracked shell (aka enclosure) on your Xbox Series X (Digital Edition) gaming console.
Cosa ti serve
Heat an iOpener and lay it on the smaller sticker near the bottom of the back panel for two minutes.
Use an iOpener or hair dryer to heat the larger sticker near the center of the back panel.
Strumento utilizzato in questo passaggio:Magnetic Project Mat$16.96
Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
Pry up the back panel to release it from the locking clips.
Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
One 10.3 mm‑long pancake screw
Two 9 mm‑long screws
Use your fingernails or a pair of angled tweezers to firmly grip the edges of the fan cable connector.
Pull the connector straight out of the socket to disconnect it.
Strumento utilizzato in questo passaggio:Dust Blower$19.99
Slide the fan out of its slot to remove it.
Before installing the fan, make sure it's clean! Use a dust blower or compressed air to blow off any dust or debris, and wipe the fan clean with a clean cloth.
Note that the fan can only be installed one way—make sure Master Chief is facing you.
Use the flat end of a spudger to pry up the locking tab holding the base to the shell.
Keep the locking tab held open for the next step.
With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
Remove the base.
Use a spudger to flip open the metal locking tab on the USB port ribbon cable.
Strumento utilizzato in questo passaggio:Tesa 61395 Tape$2.95
Slide an opening pick under the USB port cable to separate the adhesive securing it.
Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
Use a T8 Torx driver to remove the three 7.4 mm‑long green screws securing the center chassis assembly to the shell.
Use an iOpener or a hair dryer to heat the power button cable.
Use a T8 Torx driver to remove the 5.5 mm‑long screw securing the power button board.
Use an iOpener or a hair dryer to heat the USB board cable.
Use a T8 Torx driver to remove the two 8.9 mm‑long screws securing the USB board enclosure:
One screw inside the shell
One screw on the bottom of the shell (where the base was)
Use your fingers to slide the USB board enclosure out from under the metal clip securing it to the shell.
Remove the enclosure.
Make sure the Pair button is properly oriented and fully inserted in its slot.
Firmly slide the enclosure into position until it snaps into place under the metal clip.
