Salta al contenuto principale
Tungsten E Power Button Repair
Cosa ti serve
  1. Tungsten E Power Button Repair, Tungsten E Disassembly: passo 1, immagine 1 di 2 Tungsten E Power Button Repair, Tungsten E Disassembly: passo 1, immagine 2 di 2
    • Remove the stylus and SD card.
    • Using a T5 torx screwdriver, remove all 4 back panel screws.
    • The screws are small and can be lost easily. Be sure to place them in a secure area.
  2. Tungsten E Power Button Repair: passo 2, immagine 1 di 3 Tungsten E Power Button Repair: passo 2, immagine 2 di 3 Tungsten E Power Button Repair: passo 2, immagine 3 di 3
    • Insert a plastic opening tool under the USB and power input slots.
    • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
  3. Tungsten E Power Button Repair: passo 3, immagine 1 di 2 Tungsten E Power Button Repair: passo 3, immagine 2 di 2
    • Your device may not have a screen protector. If not, you can move on to step four.
    • Remove the screen protector by lifting the hinge out of the plastic housing.
    • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
  4. Tungsten E Power Button Repair: passo 4, immagine 1 di 2 Tungsten E Power Button Repair: passo 4, immagine 2 di 2
    • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
    • Using a spudger, unlock both sides of the flex connector block by pushing down.
    • Remove motherboard completely.
    • Metal washers may pop out of the device during this step
  5. Tungsten E Power Button Repair: passo 5, immagine 1 di 3 Tungsten E Power Button Repair: passo 5, immagine 2 di 3 Tungsten E Power Button Repair: passo 5, immagine 3 di 3
    • Remove buttons using fingers.
    • Gently flex frame to release screen from plastic frame.
    • Lift out screen.
  6. Tungsten E Power Button Repair: passo 6, immagine 1 di 1
    • Congratulations! You have successfully taken apart a Palm Tungsten E.
  7. Tungsten E Power Button Repair, Tungsten E Power Button Repair: passo 7, immagine 1 di 1
  8. Tungsten E Power Button Repair: passo 8, immagine 1 di 1
    • On the motherboard, find the power button near the upper right corner.
    • Check for disconnection of the power button.
  9. Tungsten E Power Button Repair: passo 9, immagine 1 di 1
    • Use soldering iron to reattach the damaged power button to the motherboard.
Conclusione
Kathleen Hix
Membro da: 01/21/10
49 Reputazione
2 Guide realizzate
Cal Poly, Team 13-22, Maness Winter 2010 Membro di Cal Poly, Team 13-22, Maness Winter 2010
CPSU-MANESS-W10S13G22
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 14
Tutti i Tempi: 5,198
