Salta al contenuto principale
Snowboard Traction Pad Replacement
Cosa ti serve
  1. Snowboard Traction Pad Replacement, Traction Pad: passo 1, immagine 1 di 2 Snowboard Traction Pad Replacement, Traction Pad: passo 1, immagine 2 di 2
    • Use a plastic or metal scraper to remove the existing traction pad.
  2. Snowboard Traction Pad Replacement: passo 2, immagine 1 di 3 Snowboard Traction Pad Replacement: passo 2, immagine 2 di 3 Snowboard Traction Pad Replacement: passo 2, immagine 3 di 3
    • If there is any residual adhesive left from the old traction pad, soak it with adhesive remover.
    • Let the adhesive remover sit for a few minutes.
    • Wipe away the residue using a towel and water.
    • Dry the the surface where the new traction pad will be placed.
  3. Snowboard Traction Pad Replacement: passo 3, immagine 1 di 3 Snowboard Traction Pad Replacement: passo 3, immagine 2 di 3 Snowboard Traction Pad Replacement: passo 3, immagine 3 di 3
    • Peel the back off of the new traction pad to reveal the adhesive.
    • When placed, the traction pad should be about an inch away from the rear binding.
    • To avoid creating air bubbles, start with one corner of the pad and roll the rest down.
    • Press down firmly to help it stick to the board and remove any air bubbles that may have occurred.
    • Give the adhesive a minimum of 12 hours to dry before use.
Linea Traguardo
Jacob Garcia
Membro da: 01/13/14
101 Reputazione
1 Guida realizzata
Cal Poly, Team 17-4, Forte Winter 2014 Membro di Cal Poly, Team 17-4, Forte Winter 2014
CPSU-FORTE-W14S17G4
5 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 3,589
