Salta al contenuto principale
Sanyo VPC S1275 Logic Board Replacement
Cosa ti serve
  1. Sanyo VPC S1275 Logic Board Replacement, Case: passo 1, immagine 1 di 3 Sanyo VPC S1275 Logic Board Replacement, Case: passo 1, immagine 2 di 3 Sanyo VPC S1275 Logic Board Replacement, Case: passo 1, immagine 3 di 3
    • Remove the following six screws using the Phillips #00 screwdriver:
    • Two screws on the left side of the camera.
    • Two screws on the right side of the camera.
    • Two screws on the bottom of the camera.
  2. Sanyo VPC S1275 Logic Board Replacement: passo 2, immagine 1 di 2 Sanyo VPC S1275 Logic Board Replacement: passo 2, immagine 2 di 2
    • Open the battery slot on the bottom of the camera by sliding the door to the right.
    • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
  3. Sanyo VPC S1275 Logic Board Replacement: passo 3, immagine 1 di 3 Sanyo VPC S1275 Logic Board Replacement: passo 3, immagine 2 di 3 Sanyo VPC S1275 Logic Board Replacement: passo 3, immagine 3 di 3
    • Insert a spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
  4. Sanyo VPC S1275 Logic Board Replacement: passo 4, immagine 1 di 1
    • This step is only needed for the case and logic board replacement
    • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
  5. Sanyo VPC S1275 Logic Board Replacement: passo 5, immagine 1 di 1
    • This step is only needed for the case replacement.
    • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
    • Slide the battery door off of the hinge.
  6. Sanyo VPC S1275 Logic Board Replacement, LCD Screen: passo 6, immagine 1 di 2 Sanyo VPC S1275 Logic Board Replacement, LCD Screen: passo 6, immagine 2 di 2
    • Using the spudger, carefully lift up the LCD screen, making sure to keep the ribbon cable intact.
    • Place the LCD screen on a non-abrasive surface.
  7. Sanyo VPC S1275 Logic Board Replacement: passo 7, immagine 1 di 1
    • Using the spudger lift the black flap up to release the ribbon cable.
    • The LCD screen will now be completely detached from the camera.
  8. Sanyo VPC S1275 Logic Board Replacement, Logic Board: passo 8, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove the four screws on the outer edge of the LCD holding plate.
  9. Sanyo VPC S1275 Logic Board Replacement: passo 9, immagine 1 di 1
    • Be careful when rotating the plate in the next step to prevent the ribbon cable in the top right from ripping.
    • Using your right hand, grab the left side of the LCD holding plate and rotate it to the right.
  10. Sanyo VPC S1275 Logic Board Replacement: passo 10, immagine 1 di 1
    • Remove the ribbon cable from its slot by gently pulling the LCD holding plate to the right.
  11. Sanyo VPC S1275 Logic Board Replacement: passo 11, immagine 1 di 2 Sanyo VPC S1275 Logic Board Replacement: passo 11, immagine 2 di 2
    • Do not touch ANY part of the logic board previously covered by the black film until the capacitor has been completely discharged. This camera has a 330V, 100 µF capacitor which can cause painful electric shock.
    • Using the spudger (or any non-metal prying tool), gently remove the black film.
  12. Sanyo VPC S1275 Logic Board Replacement: passo 12, immagine 1 di 1
    • Using the capacitor discharge tool carefully touch each end of the capacitor discharge tool to the each terminal of the capacitor.
    • Click the link below for instructions on how to make the capacitor discharge tool: Costruire uno strumento per scaricare condensatori
    • NEVER touch both both capacitor terminals with just one of the wires. This will create a potentially dangerous large spark. This will also cause serious damage to the camera.
    • Keep the wires connected to the capacitor terminals for 2 minutes to completely discharge the capacitor.
    • The camera should be completely safe to handle now.
  13. Sanyo VPC S1275 Logic Board Replacement: passo 13, immagine 1 di 1
    • Touch the hot tip of the solding iron to the first solder connecting the flash mechanism to the logic board until the solder melts.
    • Repeat this for the next 10 solders.
    • Verify solders have detached logic board.
  14. Sanyo VPC S1275 Logic Board Replacement: passo 14, immagine 1 di 1
    • Touch the hot soldering iron to the solder in the lower left corner connecting the logic board to the red wire.
    • When the solder has completely melted, gently pull the wire free from the logic board.
    • Repeat for the red, blue, and then black wires.
  15. Sanyo VPC S1275 Logic Board Replacement: passo 15, immagine 1 di 2 Sanyo VPC S1275 Logic Board Replacement: passo 15, immagine 2 di 2
    • Touch the soldering iron tip to the solder in the upper right corner connecting the logic board to the battery lead.
    • Pull the battery lead out of the slot in the logic board. This must be done immeadiately after the solder melts.
    • Repeat for the solder to the left.
    • The logic board will now be completely free from the camera.
  16. Sanyo VPC S1275 Logic Board Replacement: passo 16, immagine 1 di 1
    • Insert the battery leads into the slots in the new logic board.
    • Solder both leads to the logic board.
Conclusione
Cal Poly, Team 24-24, Regan Spring 2010 Membro di Cal Poly, Team 24-24, Regan Spring 2010
CPSU-REGAN-S10S24G24
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 24
Tutti i Tempi: 4,292
