Pericolo
Potenzialmente Pericoloso
Possibilità di infortunio se questa procedura non viene seguita correttamente. Prestare attenzione e seguire tutte le avvertenze.
Pericolo
Parti
Nessuna parte richiesta.
Disconnect the power supply cord from the outlet.
  • Disconnect the power supply cord from the outlet.
Aggiungi Commento
Remove the eight screws holding the wood-patterned cover to the microwave frame. The first four screws are located on either side of the microwave front.
  • Remove the eight screws holding the wood-patterned cover to the microwave frame.
  • The first four screws are located on either side of the microwave front.
Aggiungi Commento
Remove the additional four screws securing the wood-paneled case to the microwave frame. Remove the additional four screws securing the wood-paneled case to the microwave frame.
  • Remove the additional four screws securing the wood-paneled case to the microwave frame.
Aggiungi Commento
Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame. Lift the case upward slowly until the case is free of the microwave. Lift the case upward slowly until the case is free of the microwave.
  • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
  • Lift the case upward slowly until the case is free of the microwave.
Aggiungi Commento
Observe the lever mechanism found just behind the door handle, inside the microwave. The plastic lever should be above the metal lever. If the metal lever is above the plastic lever, this is why the door will not open.
  • Observe the lever mechanism found just behind the door handle, inside the microwave.
  • The plastic lever should be above the metal lever. If the metal lever is above the plastic lever, this is why the door will not open.
  • In this picture, the metal part is ABOVE the white plastic part. The white part needs to be lifted to open the door so when the door lever is pressed, the metal part rises, and the plastic part stays in place.
Aggiungi Commento
Lift up on the outside lever. Push up on the white plastic piece. Push metal bar down, snapping the white plastic piece above it.
  • Lift up on the outside lever.
  • Push up on the white plastic piece.
  • Push metal bar down, snapping the white plastic piece above it.
Aggiungi Commento
This is how the fixed mechanism should look. Press the button and enjoy your newly fixed door!
  • This is how the fixed mechanism should look.
  • Press the button and enjoy your newly fixed door!
Aggiungi Commento
Conclusione
Samuel
Membro da: 26/09/2012
100 Reputazione
2 Guide realizzate
Cal Poly, Team 2-12, Propen Fall 2012 Membro di Cal Poly, Team 2-12, Propen Fall 2012
CPSU-PROPEN-F12S2G12
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,154
