Parti
Nessuna parte richiesta.
Eject the disk tray from the DVD player before removing power supply.
  • Eject the disk tray from the DVD player before removing power supply.
Aggiungi Commento
Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier dissasembly of the player.
  • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier dissasembly of the player.
Aggiungi Commento
Remove 3 screws running along back edge of case cover. Remove 2 screws from each side of case cover.
  • Remove 3 screws running along back edge of case cover.
  • Remove 2 screws from each side of case cover.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Grab edges of cover, pull outward slightly, and pull straight up.
  • Grab edges of cover, pull outward slightly, and pull straight up.
Aggiungi Commento
Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player. Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player.
  • Lift up the 5 tabs securing the front panel to the chassis. There are 3 on the bottom, and 2 on the inside edges of the panel. Panel should then lift off the player.
Aggiungi Commento
Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector. Place forefinger under cable loop as shown, gripping with thumb.
  • Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
  • Place forefinger under cable loop as shown, gripping with thumb.
  • Pull straight up. It should disconnect with little force.
Aggiungi Commento
Using tweezers or pliers, squeeze the tabs of the plastic fasteners together. While doing this, gently lift up on the motherboard until the fasteners are released. Using tweezers or pliers, squeeze the tabs of the plastic fasteners together. While doing this, gently lift up on the motherboard until the fasteners are released.
  • Using tweezers or pliers, squeeze the tabs of the plastic fasteners together. While doing this, gently lift up on the motherboard until the fasteners are released.
Aggiungi Commento
Remove the two screws securing the motherboard using a philips screw driver.
  • Remove the two screws securing the motherboard using a philips screw driver.
Aggiungi Commento
Lift the board from the side closest to the front panel (top of photo).
  • Lift the board from the side closest to the front panel (top of photo).
  • Gently apply force until bottom connector releases from power board below.
Aggiungi Commento
Conclusione
Kevin
Membro da: 26/04/2011
351 Reputazione
8 Guide realizzate
Cal Poly, Team 18-20, Garner Spring 2011 Membro di Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Membri
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,575
