Salta al contenuto principale
RCA Small Wonders Camcorder CC176 Speaker Replacement
Cosa ti serve
  1. RCA Small Wonders Camcorder CC176 Speaker Replacement, Speaker: passo 1, immagine 1 di 3 RCA Small Wonders Camcorder CC176 Speaker Replacement, Speaker: passo 1, immagine 2 di 3 RCA Small Wonders Camcorder CC176 Speaker Replacement, Speaker: passo 1, immagine 3 di 3
    • Remove the small black screws along the edges of the control panel on the top of the device.
    • Pry off the top control panel using the plastic wedge tool.
    • Remove the screw from the front, gray panel located beneath the "Scene Select AE" label.
    • Remove the two small black screws on the top of the front, gray panel of the device, above the red AUTOFOCUS letters.
  2. RCA Small Wonders Camcorder CC176 Speaker Replacement: passo 2, immagine 1 di 1
    • Turn the device over and remove the two screws securing the front panel of the device.
    • Remove the screw securing the primary viewfinder, along the front of the camera.
    • Using a flat plastic tool, pry the entire front panel away from the device.
  3. RCA Small Wonders Camcorder CC176 Speaker Replacement: passo 3, immagine 1 di 2 RCA Small Wonders Camcorder CC176 Speaker Replacement: passo 3, immagine 2 di 2
    • Gently unplug the grey cord, located underneath the panel, disconnecting the speaker from the inner component of the device.
    • Remove the speaker from the device.
Conclusione
James Madison, Team 2-1, Allen Fall 2011 Membro di James Madison, Team 2-1, Allen Fall 2011
JMU-ALLEN-F11S2G1
2 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 907
