Salta al contenuto principale
Plantronics CS50 Headset Motherboard Replacement
Cosa ti serve
  1. Plantronics CS50 Headset Motherboard Replacement, Battery: passo 1, immagine 1 di 3 Plantronics CS50 Headset Motherboard Replacement, Battery: passo 1, immagine 2 di 3 Plantronics CS50 Headset Motherboard Replacement, Battery: passo 1, immagine 3 di 3
    • Flip the headset face down.
    • Squeeze both sides of the battery cover.
    • While squeezing, pull the cover up slowly to remove it.
  2. Plantronics CS50 Headset Motherboard Replacement: passo 2, immagine 1 di 3 Plantronics CS50 Headset Motherboard Replacement: passo 2, immagine 2 di 3 Plantronics CS50 Headset Motherboard Replacement: passo 2, immagine 3 di 3
    • Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
  3. Plantronics CS50 Headset Motherboard Replacement, Microphone: passo 3, immagine 1 di 2 Plantronics CS50 Headset Motherboard Replacement, Microphone: passo 3, immagine 2 di 2
    • Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components.
    • Apply additional heat at the tip of the microphone.
  4. Plantronics CS50 Headset Motherboard Replacement: passo 4, immagine 1 di 2 Plantronics CS50 Headset Motherboard Replacement: passo 4, immagine 2 di 2
    • After heating the headset, use the plastic opening tool to carefully pry the black cover from the headset.
    • Be aware of the two plastic connectors inside the headset. If the black cover does not come off smoothly, apply additional heat on the connectors.
  5. Plantronics CS50 Headset Motherboard Replacement: passo 5, immagine 1 di 2 Plantronics CS50 Headset Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove the microphone from the tip of the plastic.
    • You will have to lift the microphone straight up because it is held in place by a small piece of plastic.
  6. Plantronics CS50 Headset Motherboard Replacement: passo 6, immagine 1 di 2 Plantronics CS50 Headset Motherboard Replacement: passo 6, immagine 2 di 2
    • Use the heat gun to melt the adhesive connecting the headset face to the speaker casing.
    • Use the plastic opening tool to separate the speaker casing from the headset face.
    • Add extra heat to the sides to melt the adhesive between the plastic connectors.
  7. Plantronics CS50 Headset Motherboard Replacement: passo 7, immagine 1 di 2 Plantronics CS50 Headset Motherboard Replacement: passo 7, immagine 2 di 2
    • Slowly separate the motherboard from the rest of the headset.
  8. Plantronics CS50 Headset Motherboard Replacement: passo 8, immagine 1 di 1
    • Locate the microphone wires on the bottom of the motherboard.
    • Use a hairdryer or heat gun to melt the glue off of the motherboard.
  9. Plantronics CS50 Headset Motherboard Replacement: passo 9, immagine 1 di 1
    • Flip the device over.
    • Use a soldering iron to remove the solder that holds the wires to the motherboard.
    • For help soldering, click here.
    • The microphone piece should be completely detached from the motherboard.
  10. Plantronics CS50 Headset Motherboard Replacement, Motherboard: passo 10, immagine 1 di 3 Plantronics CS50 Headset Motherboard Replacement, Motherboard: passo 10, immagine 2 di 3 Plantronics CS50 Headset Motherboard Replacement, Motherboard: passo 10, immagine 3 di 3
    • Using a blow dryer or a heat gun, heat the crevice to melt the adhesive between the plastic covers.
    • Using a plastic opening tool, prop open the edges.
    • Gently pull the black speaker casing up to remove it.
  11. Plantronics CS50 Headset Motherboard Replacement: passo 11, immagine 1 di 2 Plantronics CS50 Headset Motherboard Replacement: passo 11, immagine 2 di 2
    • Use the heat gun or blow dryer to melt the glue that connects the wires to the headset's motherboard.
    • The wires should come off as they are not soldered to the motherboard.
Conclusione
Joe
Membro da: 04/12/12
99 Reputazione
3 Guide realizzate
Cal Poly, Team 17-29, Amido Spring 2012 Membro di Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 15
Tutti i Tempi: 994
