Introduzione
In this guide, you will locate several screws that hold the top panel in place and remove them. They are all Phillips screws and are simple to remove.
Parti
Nessuna parte richiesta.
Remove four 7.5 mm Phillips screws on the both sides (2 on each side). Remove five 7.5 mm Phillips screws on the back of the player.
  • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
  • Remove five 7.5 mm Phillips screws on the back of the player.
Aggiungi Commento
Guida ai regali per la festa del papà
Facciamo onore non solo ai nostri padri — festeggiamo tutti i mentori che ci hanno insegnato a riparare.
Facciamo onore a chi ci ha insegnato a riparare.
Lift the top panel from the back and remove.  It should come off without being forced.  There is a lip near the front so you many need to slide the top panel back slightly to remove it. Lift the top panel from the back and remove.  It should come off without being forced.  There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Nathan Klammer
Membro da: 06/10/2011
263 Reputazione
3 Guide realizzate
Cal Poly, Team 21-20, Maness Fall 2011 Membro di Cal Poly, Team 21-20, Maness Fall 2011
CPSU-MANESS-F11S21G20
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 822
