Introduzione
This guide will teach you how to replace defective buttons. You may need to clean under the buttons if you have sticky buttons.
Cosa ti serve
Pull down on the battery cover release lever and pull back to remove the cover.
Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
Altre 5 persone hanno completato questa guida.
