Salta al contenuto principale
Motorola Droid Turbo Battery Replacement
Cosa ti serve
  1. Motorola Droid Turbo Battery Replacement, Rear Case: passo 1, immagine 1 di 1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Battery Replacement: passo 2, immagine 1 di 2 Motorola Droid Turbo Battery Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Battery Replacement, Midframe: passo 3, immagine 1 di 1
    • Remove the midframe bezel.
  4. Motorola Droid Turbo Battery Replacement: passo 4, immagine 1 di 1
    • Remove the four Torx T5 screws securing the midframe plate.
  5. Motorola Droid Turbo Battery Replacement: passo 5, immagine 1 di 1
    • Remove the midframe.
  6. Motorola Droid Turbo Battery Replacement, Battery: passo 6, immagine 1 di 2 Motorola Droid Turbo Battery Replacement, Battery: passo 6, immagine 2 di 2
    • Use the point of a spudger to pop up the battery connector.
  7. Motorola Droid Turbo Battery Replacement: passo 7, immagine 1 di 2 Motorola Droid Turbo Battery Replacement: passo 7, immagine 2 di 2
    • Fold the wireless charging coil away from the battery.
  8. Motorola Droid Turbo Battery Replacement: passo 8, immagine 1 di 2 Motorola Droid Turbo Battery Replacement: passo 8, immagine 2 di 2
    • Use a spudger to gently pry the battery up from the rest of the device.
    • The battery is secured with some moderate adhesive, so some force may be necessary.
Conclusione
Altre 60 persone hanno completato questa guida.
USF Tampa, Team 15-5, Remmell Spring 2016 Membro di USF Tampa, Team 15-5, Remmell Spring 2016
USFT-REMMELL-S16S15G5
3 Membri
6 Guide realizzate
34 Commenti
The screws that attach the black plastic in step 3 are NOT #2 phillips. This is reasonably obvious from the photo but the misleading caption should be changed. They are T5 Torx bit screws. Also, the plastic camera sub assembly in step 4 has 3 small t shaped tabs that shear if you pry it away from the phone. I could not see a way to remove the sub assembly without damaging the tabs so the 4 T5 screws will have to keep it in place from now on.
Jeffrey Sauter - Replica
Hey Jeffrey! Thanks for the heads up. Feel free to edit the guide steps as you see fit by selecting Edit in the top right corner of the guide step in question. We changed the permissions so you should be able to edit the text. Thanks again for contributing!
Kelsea Weber -
Do you need to apply fresh adhesive when re-assembling?
Richard Klein - Replica
Do you need to apply adhesive when re assembling?
ben_martell - Replica
the adhesive is 3 narrow pieces of double sided tape. You can carefully peel it off the old battery and reuse it. I don't see where it's absolutely necessary though. The battery isn't going to move around after the phone is put back together.
Mike Mangiaruca -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 45
Tutti i Tempi: 85,537
