Salta al contenuto principale
Minolta Dimage Xt Flash Capacitor Replacement
Cosa ti serve
  1. Minolta Dimage Xt Flash Capacitor Replacement, Casing: passo 1, immagine 1 di 3 Minolta Dimage Xt Flash Capacitor Replacement, Casing: passo 1, immagine 2 di 3 Minolta Dimage Xt Flash Capacitor Replacement, Casing: passo 1, immagine 3 di 3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Flash Capacitor Replacement: passo 2, immagine 1 di 3 Minolta Dimage Xt Flash Capacitor Replacement: passo 2, immagine 2 di 3 Minolta Dimage Xt Flash Capacitor Replacement: passo 2, immagine 3 di 3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: passo 3, immagine 1 di 2 Minolta Dimage Xt Flash Capacitor Replacement, Flash Capacitor: passo 3, immagine 2 di 2
    • Caution: Touching the capacitor leads may cause serious injury. Use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • On the front side of the camera, locate the flash battery holder.
    • Lift the housing and remove the battery.
    • After removing the battery, clip the wires and solder the replacement battery.
Conclusione
Qqq
Membro da: 03/11/13
19 Reputazione
1 Guida realizzata
Un commento
Its a cap not a battery :D
Eigirdas Gedgaudas - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 13
Tutti i Tempi: 998
