Salta al contenuto principale
MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement
Cosa ti serve
  1. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement, Lower Case: passo 1, immagine 1 di 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
    Chiedi a FixBot
    Aggiungi Commento
  2. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 2, immagine 1 di 1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
    Chiedi a FixBot
    Aggiungi Commento
  3. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement, Battery Connector: passo 3, immagine 1 di 1
    • Peel back the warning label covering the battery connector.
    Chiedi a FixBot
    Aggiungi Commento
  4. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 4, immagine 1 di 2 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 4, immagine 2 di 2
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  5. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement, AirPort/Camera Cable: passo 5, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
    • The cable connection points are fragile. Be careful to lift only on the connector, and not on the socket or cable.
    • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
    Chiedi a FixBot
    Aggiungi Commento
  6. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 6, immagine 1 di 1
    • Use the tip of a spudger to push the camera cable's plug toward the fan and out of its socket on the logic board.
    • The plug in the photo has six connections, but some models have twelve connections. The process of removing the plug from its socket is the same for both.
    • If the camera cable's plug won't come easily out of its socket on the logic board, fold back the rubber cover over the fan to gain access to the cable, then gently pull on the cable while using the spudger to gently push the plug out of its socket.
    • Be sure to push parallel to the board, first on one side, then the other, to slowly "walk" the plug out of its socket. Do not pry up, or you will damage the socket.
    Chiedi a FixBot
    Aggiungi Commento
  7. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 7, immagine 1 di 3 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 7, immagine 2 di 3 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 7, immagine 3 di 3
    • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
    • Slide the spudger underneath the length of the cover, releasing the adhesive.
    • Lift the cover and flip it back so that you can access the cables underneath.
    Chiedi a FixBot
    Aggiungi Commento
  8. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 8, immagine 1 di 3 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 8, immagine 2 di 3 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 8, immagine 3 di 3
    • Use your fingers to pull the AirPort/Camera cables up off the fan.
    • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
    • Carefully de-route the cables from the plastic cable guide.
    Chiedi a FixBot
    Aggiungi Commento
  9. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement, Rubber Hinge Covers: passo 9, immagine 1 di 2 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement, Rubber Hinge Covers: passo 9, immagine 2 di 2
    • Use the flat end of a spudger to pry the rubber hinge covers up off the left and right hinges.
    Chiedi a FixBot
    Aggiungi Commento
  10. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement, I/O Board Cable: passo 10, immagine 1 di 3 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement, I/O Board Cable: passo 10, immagine 2 di 3 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement, I/O Board Cable: passo 10, immagine 3 di 3
    • If your I/O Board cable's connectors have notches in the padding, you will need to release a locking lever underneath the notch in order to remove the cable. If this is the case, don't pry up on the connector until the levers are unlatched.
    • Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
    • During reassembly, connect this end first, as it does not flex.
    • In a similar fashion, remove the I/O Board cable connector from its socket on the I/O Board.
    • Remove the I/O Board cable from the MacBook Pro.
    Chiedi a FixBot
    Aggiungi Commento
  11. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement, Airport Card: passo 11, immagine 1 di 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort card to the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  12. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 12, immagine 1 di 2 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 12, immagine 2 di 2
    • Grasp the sides of the AirPort card and lift it up to a shallow angle (5-10˚) to separate the light adhesive adhering it to the logic board.
    • Pull the AirPort card parallel out of its connector on the logic board to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  13. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 13, immagine 1 di 2 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 13, immagine 2 di 2
    • Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Starting at the top of the cable, slide a plastic opening tool under the right fan cable to free it from the logic board.
    • Use caution when freeing the cable, as it is strongly adhered to the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  14. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 14, immagine 1 di 1
    • Remove the following three screws securing the right fan to the logic board:
    • One 4.4 mm T5 Torx screw
    • One 3.9 mm T5 Wide Head Torx screw
    • One 5.0 mm T5 Torx screw with 2 mm collar
    Chiedi a FixBot
    Aggiungi Commento
  15. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 15, immagine 1 di 1
    • Lift and remove the right fan out from the MacBook Pro.
    • When reinstalling the fan, it's easiest connect the fan ribbon cable as you drop the fan in place, rather than after you've installed the three fan screws.
    Chiedi a FixBot
    Aggiungi Commento
  16. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement, Left Fan: passo 16, immagine 1 di 1
    • Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
    Chiedi a FixBot
    Aggiungi Commento
  17. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 17, immagine 1 di 1
    • Remove the following three screws securing the left fan to the logic board:
    • One 4.4 mm T5 Torx screw with 2 mm collar
    • When reinstalling the fan and its screws, don't fully torque the screws until you've first installed all of them loosely, so that the fan can move a little and position itself properly as you insert the screws into their threaded standoffs.
    Chiedi a FixBot
    Aggiungi Commento
  18. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 18, immagine 1 di 3 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 18, immagine 2 di 3 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 18, immagine 3 di 3
    • Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
    • Starting at the top of the cable, slide a plastic opening tool under the left fan cable to free it from the logic board.
    • Use caution when freeing the cable, as it is strongly adhered to the logic board. If necessary, use an iOpener or hair dryer to heat the cable in order to soften the adhesive and make it easier to remove.
    • Lift the left fan out of the device.
    • When reinstalling the fan, it's easier to connect the fan ribbon cable as you drop the fan in place, rather than after you've installed the three fan screws.
    Chiedi a FixBot
    Aggiungi Commento
  19. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement, SSD: passo 19, immagine 1 di 1
    • Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  20. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 20, immagine 1 di 2 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 20, immagine 2 di 2
    • Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  21. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement, I/O Board: passo 21, immagine 1 di 2 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement, I/O Board: passo 21, immagine 2 di 2
    • Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer.
    • Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
    • Do not lift up on the I/O board data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  22. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 22, immagine 1 di 3 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 22, immagine 2 di 3 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 22, immagine 3 di 3
    • Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
    • On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal.
    • Carefully lift the I/O board and remove it from the lower case.
    Chiedi a FixBot
    Aggiungi Commento
  23. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement, Logic Board Removal: passo 23, immagine 1 di 2 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement, Logic Board Removal: passo 23, immagine 2 di 2
    • Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the logic board.
    • Use the tip of a spudger to pry the right speaker connector up and out of its socket on the logic board
    • Be sure to pry on the cable head, and not on the socket itself. Prying on the socket may cause it to separate from the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  24. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 24, immagine 1 di 3 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 24, immagine 2 di 3 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 24, immagine 3 di 3
    • Peel back the tape covering the top of the keyboard ribbon cable connector.
    • Use the flat end of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Use the flat end of a spudger to push the keyboard ribbon cable out of its socket.
    Chiedi a FixBot
    Aggiungi Commento
  25. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 25, immagine 1 di 1
    • Use the flat end of a spudger to pry the trackpad ribbon cable connector up out of its socket.
    Chiedi a FixBot
    Aggiungi Commento
  26. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 26, immagine 1 di 1
    • Use the flat end of a spudger to pry the keyboard backlight connector up from its socket on the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  27. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 27, immagine 1 di 1
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Pull the microphone ribbon cable out of its socket.
    Chiedi a FixBot
    Aggiungi Commento
  28. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 28, immagine 1 di 2 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 28, immagine 2 di 2
    • Use the tip of a spudger to flip up the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  29. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 29, immagine 1 di 1
    • Use the flat end of a spudger to carefully pry off the rubber screw cap on the raised screw head near the MagSafe 2 connector.
    • The location of this screw may vary between models.
    Chiedi a FixBot
    Aggiungi Commento
  30. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 30, immagine 1 di 1
    • Remove the following six screws securing the logic board to to the upper case:
    • One 3.1 mm T5 Torx screw
    • One 2.5 mm T5 Torx screw
    • One 5.5 mm silver, raised-head T5 Torx screw
    • Two 5.7 mm T5 Torx screws
    • One 3.8 mm silver T5 Torx screw
    Chiedi a FixBot
    Aggiungi Commento
  31. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 31, immagine 1 di 2 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 31, immagine 2 di 2
    • Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro.
    • You may need to slide the logic board a few millimeters to the left in order to get clearance for the ports along the right edge of the board.
    • Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board.
    • Disconnecting the MagSafe 2 connector can be difficult. If you are only removing the logic board to temporarily get it out of the way, such as for a battery replacement, you may find it easier to simply remove the two 2.5 mm T5 Torx screws securing the MagSafe DC-In board, and then remove the logic board and MagSafe board together.
    Chiedi a FixBot
    Aggiungi Commento
  32. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 32, immagine 1 di 3 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 32, immagine 2 di 3 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement: passo 32, immagine 3 di 3
    • Remove the logic board assembly from the MacBook Pro.
    • While the logic board and fans are removed, use a can of compressed air and a soft, non-static brush to remove dust and other debris from the upper case and the logic board, particularly from the fan exhaust openings along the rear edge of the upper case.
    • When reinstalling the motherboard, make sure all cables, and the two rubber heat sink/fan covers, are visible and not trapped under the motherboard.
    • Second photo, clockwise from top: battery, right speaker, keyboard backlight, AirPort/camera, display, microphone, left speaker, keyboard, and trackpad.
    Chiedi a FixBot
    Aggiungi Commento
  33. MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement, MagSafe DC-In Board: passo 33, immagine 1 di 2 MacBook Pro 15" Retina Display Mid 2014 MagSafe DC-In Board Replacement, MagSafe DC-In Board: passo 33, immagine 2 di 2
    • Rotate the device 180 degrees to more easily access the rest of the internal components.
    • Remove the two 2.5 mm T5 Torx screws securing the MagSafe DC-In board to the upper case.
    • Slide the MagSafe DC-In board towards the right to free it from its recess within the upper case.
    • Lift and remove the MagSafe DC-In board out of the upper case assembly.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 47 persone hanno completato questa guida.
29Commenti sulla guida
Thanks! I just completed this repair on a 15” mid 2015. It’s almost identical except there are some extra shields to remove from some of the connections (IO board cable connections, touch pad connection) which are very obvious.
I accidentally broke the flip/hinge for the ZIF on the right fan but it doesn’t seem to be an issue because the cable fits in snug anyways.
Christopher Reid - Rispondi Condividi
thanks a lot! I did the same repair on a 15” mid 2015 and encountered the same issues described already by Christopher. Had also a broken flip on the ZIF of the right fan. But everything works again.
Georges Moes - Rispondi Condividi
I have now replaced the battery and the dc-in board, and I still can’t get the battery to charge. I also bought a new magsafe power adapter. It appears all cables are connected, and the computer runs fine on the battery (until it runs out of juice, then I will be at a complete loss). No clue what to try next. Any suggestions? Thanks!
matt rogers - Rispondi Condividi
I thought I was the only one having the same problems. I haven’t replaced my dc-in board yet nor the charger. I’m sure this has something to do with the new Battery Health Management, MacOS 10.15.5 update served. Now I just don’t know how to use my mac when the battery is 0%. Last time I could charge it by taking the battery plug out of logic board and simply putting it back in and then it charged. Any suggestions are welcome here too.
Aleksi Lohisto - Rispondi Condividi
Just to add. When I have my Macbook open and charger plugged in, it shows the red charging light, but in MacOS it tells its actually not charging. When I close the lid, the red charging indicator will go off after a while, and to get it back working (reset the magsafe chargers fault mode or something), I have to take the charger out of wall socket.
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 8
Ultimi 7 giorni: 83
Ultimi 30 giorni: 256
Tutti i Tempi: 42,743
