Salta al contenuto principale
MacBook Core Duo Hard Drive Replacement
Cosa ti serve
Panoramica video
  1. MacBook Core Duo Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
    Chiedi a FixBot
    Aggiungi Commento
  2. MacBook Core Duo Hard Drive Replacement: passo 2, immagine 1 di 1
    • Lift the battery out of the computer.
    Chiedi a FixBot
    Aggiungi Commento
  3. MacBook Core Duo Hard Drive Replacement, Memory Cover: passo 3, immagine 1 di 1
    • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover.
    • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
    Chiedi a FixBot
    Aggiungi Commento
  4. MacBook Core Duo Hard Drive Replacement: passo 4, immagine 1 di 1
    • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
    Chiedi a FixBot
    Aggiungi Commento
  5. MacBook Core Duo Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 1
    • Grasp the white plastic tab attached to the hard drive and pull it to the right, removing the hard drive from the computer.
    • The hard drive goes back into its compartment with the label facing down.
    Chiedi a FixBot
    Aggiungi Commento
  6. MacBook Core Duo Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 1
    • Remove the two black T8 Torx screws securing the silver bracket to the hard drive.
    Chiedi a FixBot
    Aggiungi Commento
  7. MacBook Core Duo Hard Drive Replacement: passo 7, immagine 1 di 1
    • Rotate the hard drive and remove the two black T8 Torx screws on the other side of the drive.
    Chiedi a FixBot
    Aggiungi Commento
  8. MacBook Core Duo Hard Drive Replacement: passo 8, immagine 1 di 1
    • Lift the silver metal hard drive bracket off of the hard drive.
    • You'll need to transfer this metal bracket to your new hard drive.
    • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 614 persone hanno completato questa guida.
iRobot
Membro da: 09/24/09
1 Reputazione
636 guide realizzate
20Commenti sulla guida
Thanks iFixit for this great walkthrough. Yes, it worked find. Have a look: http://www.vimeo.com/17134347 ;) Keep on rockin' /Sebastian
Sebastian Perschke - Rispondi Condividi
Any suggestions for when the rubber track comes out with the hard disk? Short of dismantling the whole thing?
billkline - Rispondi Condividi
I saw no replies to the "black rubber lip in the slot" comment. What is the fix for that rubber liner track strip coming loose from the inside of the HD enclosure, please?
Mike - Rispondi Condividi
Thanks for the guide, iFixit! It worked like a cham.
scheppdogg532 - Rispondi Condividi
I was wondering if there are any harddrives that are known to be incompatible with this MacBook (aside from dimensions of course)?
Jeannine Guenette - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 7
Ultimi 7 giorni: 54
Ultimi 30 giorni: 246
Tutti i Tempi: 437,203
