Salta al contenuto principale
Lenovo Yoga C930-13IKB Wi-Fi Card Replacement
Cosa ti serve
  1. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement, Back Cover: passo 1, immagine 1 di 1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: passo 2, immagine 1 di 2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: passo 2, immagine 2 di 2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: passo 3, immagine 1 di 2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: passo 3, immagine 2 di 2
    • Carefully lift the cover off with your hands.
  4. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement, Wi-Fi Card: passo 4, immagine 1 di 2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement, Wi-Fi Card: passo 4, immagine 2 di 2
    • Find the Wi-Fi card located on the right just above the battery. It is a green chip with a white label that says "Intel 9260" somewhere on it.
  5. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: passo 5, immagine 1 di 2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: passo 5, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the single 2 mm screw that attaches the card to the motherboard.
  6. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: passo 6, immagine 1 di 3 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: passo 6, immagine 2 di 3 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    iFixit Opening Tool
    $1.99
    Compra
    • Gently pull or use the iFixit opening tool to detach the black and white wires from the card.
    • When reassembling, these wires are difficult to reattach, so be patient. Line the wires up with your fingers and press down on the connections with the opening tool.
  7. Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: passo 7, immagine 1 di 2 Lenovo Yoga C930-13IKB Wi-Fi Card Replacement: passo 7, immagine 2 di 2
    • Pinch the card on either side and pull to the right to unplug it from the motherboard.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team S19-G5, White Winter 2020 Membro di Cal Poly, Team S19-G5, White Winter 2020
CPSU-WHITE-W20S19G5
4 Membri
16 Guide realizzate
Un commento
Brilliant! very clear instructions and it fixed my fault. I wonder if this is a relatively common fault. Windows unable to find WiFi adapter.
Thank you for your efforts
David Pugh - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 38
Tutti i Tempi: 1,403
