Salta al contenuto principale
Lenovo Yoga 720-15IKB Fan Replacement
Cosa ti serve
  1. Lenovo Yoga 720-15IKB Fan Replacement, Bottom Cover: passo 1, immagine 1 di 3 Lenovo Yoga 720-15IKB Fan Replacement, Bottom Cover: passo 1, immagine 2 di 3 Lenovo Yoga 720-15IKB Fan Replacement, Bottom Cover: passo 1, immagine 3 di 3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Fan Replacement: passo 2, immagine 1 di 2 Lenovo Yoga 720-15IKB Fan Replacement: passo 2, immagine 2 di 2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Fan Replacement, Fan: passo 3, immagine 1 di 2 Lenovo Yoga 720-15IKB Fan Replacement, Fan: passo 3, immagine 2 di 2
    • Remove the six 5.2mm Torx T5 screws holding the fan in place.
    • Remove the five 5.0mm Torx T5 screws holding the fan in place.
  4. Lenovo Yoga 720-15IKB Fan Replacement: passo 4, immagine 1 di 3 Lenovo Yoga 720-15IKB Fan Replacement: passo 4, immagine 2 di 3 Lenovo Yoga 720-15IKB Fan Replacement: passo 4, immagine 3 di 3
    • Disconnect the two fan wire connectors.
    • Firmly pull the connector out horizontally away from the socket.
    • Carefully lift the fan up and out.
Conclusione
Altre 6 persone hanno completato questa guida.
Shaina Bagri
Membro da: 01/23/20
447 Reputazione
2 Guide realizzate
Cal Poly, Team S19-G3, White Winter 2020 Membro di Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
4 Membri
25 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 63
Tutti i Tempi: 3,504
