Salta al contenuto principale
Lenovo Yoga 710-15IKB Battery Replacement
Cosa ti serve
  1. Lenovo Yoga 710-15IKB Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Battery Replacement: passo 2, immagine 1 di 1
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Battery Replacement: passo 3, immagine 1 di 1
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Battery Replacement: passo 4, immagine 1 di 1
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Battery Replacement: passo 5, immagine 1 di 1
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Battery Replacement: passo 6, immagine 1 di 1
    • Gently lift and remove the battery.
Conclusione
Altre 15 persone hanno completato questa guida.
2 Commenti
I had to use a PH000 screwdriver and was only able to remove 1 of the battery screws from the original Lenovo battery. Any suggestions on how to remove the others? Where can I get replacement screws?
karenosickey - Replica
The battery cable requires a lot of force to disconnect; tweezers won't cut it. It's also difficult to reconnect the battery. I used two pairs of needle-nose pliers to squeeze the connector into the socket on both sides.
jkvmyxud - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 103
Tutti i Tempi: 18,590
