Salta al contenuto principale
Lenovo Yoga 2 13" Battery Replacement
Cosa ti serve
  1. Lenovo Yoga 2 13" Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Be sure to power off and unplug your device before you begin your repair.
    • With a T5 Torx screwdriver, remove eleven 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 13" Battery Replacement: passo 2, immagine 1 di 1
    • Carefully separate back panel from the laptop.
  3. Lenovo Yoga 2 13" Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Locate the battery of the laptop.
  4. Lenovo Yoga 2 13" Battery Replacement: passo 4, immagine 1 di 1
    • To remove the battery, use a Phillips head screwdriver to unscrew three 3.175 mm screws. One will be in the center of the battery (covered by a Lenovo sticker) and the other two are in the corners.
  5. Lenovo Yoga 2 13" Battery Replacement: passo 5, immagine 1 di 1
    • Disconnect the battery from the laptop by pulling the power connector towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Yoga 2 13" Battery Replacement: passo 6, immagine 1 di 1
    • Once all wires are unattached to the rest of the computer, remove the battery from the laptop and replace.
Conclusione
Altre 12 persone hanno completato questa guida.
Nichelle
Membro da: 03/11/15
1.550 Reputazione
5 Guide realizzate
Marist, Team 1-2, Laflen Spring 2015 Membro di Marist, Team 1-2, Laflen Spring 2015
MARS-LAFLEN-S15S1G2
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 70
Tutti i Tempi: 31,661
