Introduzione
Batteries wear out over time and should be replaced if battery life becomes excessively short. Before removing this battery, be sure that the computer is turned off and unplugged.
Parti
Nessuna parte richiesta.
Remove all twelve 6 mm long screws on the back of the laptop with a Phillips #1 screwdriver. Apply a lot of pressure to prevent the screws from stripping.
  • Remove all twelve 6 mm long screws on the back of the laptop with a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
    • Make sure to turn off the computer first!
Aggiungi Commento
Gently pull off the back cover of the laptop. It should come off easily. Gently pull off the back cover of the laptop. It should come off easily.
  • Gently pull off the back cover of the laptop. It should come off easily.
Aggiungi Commento
Remove all four 6 mm screws from the battery using the Phillips #1 screwdriver. Remove all four 6 mm screws from the battery using the Phillips #1 screwdriver.
  • Remove all four 6 mm screws from the battery using the Phillips #1 screwdriver.
Aggiungi Commento
Unplug the battery from the computer. Do not pull too hard on the battery cable, as this can damage the battery's connection to the laptop.
  • Unplug the battery from the computer.
    • Do not pull too hard on the battery cable, as this can damage the battery's connection to the laptop.
Aggiungi Commento
Lift the battery out of the computer. Lift the battery out of the computer.
  • Lift the battery out of the computer.
Aggiungi Commento
Conclusione
Altre 11 persone hanno completato questa guida.
Nicholas Hardy
Membro da: 20/01/2015
224 Reputazione
2 Guide realizzate
Cal Poly, Team 18-1, Maness Winter 2015 Membro di Cal Poly, Team 18-1, Maness Winter 2015
CPSU-MANESS-W15S18G1
5 Membri
7 Guide realizzate
Is it possible to replace the original battery with one that has a larger capacity? With this I mean if the original battery has 3700 mAh, can it be replaced by a battery with e.g. 5000 mAh?
Piet Sjonson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 47
Ultimi 7 Giorni: 314
Ultimi 30 Giorni: 1,431
Tutti i Tempi: 34,736
