Salta al contenuto principale
Lenovo ThinkPad T560 Fan Replacement
Cosa ti serve
  1. Lenovo ThinkPad T560 Fan Replacement, Back Panel: passo 1, immagine 1 di 1
    • Before you begin this guide, make sure to disable the internal battery, power down the device and disconnect from any external power sources.
    • The external battery should be removed prior to back panel disassembly however this device doesn't have one so we aren't able to show the process.
    • Using the Phillips #0 screwdriver, remove the eight 7 mm screws holding the back panel to the T560.
  2. Lenovo ThinkPad T560 Fan Replacement: passo 2, immagine 1 di 1
    • Use the iFixit opening tool to pry the back panel off your T560.
    • Work your way around the perimeter of the device to undo the clips and detach the back panel.
  3. Lenovo ThinkPad T560 Fan Replacement, Battery: passo 3, immagine 1 di 2 Lenovo ThinkPad T560 Fan Replacement, Battery: passo 3, immagine 2 di 2
    • Disconnect the battery connector from the motherboard by pulling it out of the port.
  4. Lenovo ThinkPad T560 Fan Replacement: passo 4, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the five 3.5 mm screws securing the battery.
    • Remove the battery.
  5. Lenovo ThinkPad T560 Fan Replacement, Fan: passo 5, immagine 1 di 3 Lenovo ThinkPad T560 Fan Replacement, Fan: passo 5, immagine 2 di 3 Lenovo ThinkPad T560 Fan Replacement, Fan: passo 5, immagine 3 di 3
    • Using the iFixit opening tool, unlatch the power button's connection to the motherboard.
    • Remove the ribbon cable from the connector.
  6. Lenovo ThinkPad T560 Fan Replacement: passo 6, immagine 1 di 1
    • Unplug the fan from the motherboard.
  7. Lenovo ThinkPad T560 Fan Replacement: passo 7, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the four 3.5 mm screws securing the heatsink.
  8. Lenovo ThinkPad T560 Fan Replacement: passo 8, immagine 1 di 1
    • Using the Phillips #0 screwdriver, unscrew the 3.5mm screw securing the fan to the case.
    • Remove the fan and conjoined heatsink.
Conclusione
Clemson, Team 1-3, Hunter Spring 2022 Membro di Clemson, Team 1-3, Hunter Spring 2022
CLEM-HUNTER-S22S1G3
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 729
