Salta al contenuto principale
Lenovo IdeaPad 330S-14IKB Battery Replacement
Cosa ti serve
  1. Lenovo IdeaPad 330S-14IKB Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Begin by turning your laptop upside down so that you can access the labels on the back.
  2. Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 2, immagine 1 di 2 Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 2, immagine 2 di 2
    • Remove the 10 screws from the bottom of the laptop.
    • Safely store these screws in a place where you won't lose them, such as a magnetic pad.
    • (Silver, 5.8mm Philips #0)
  3. Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 3, immagine 1 di 1
    • Slowly and carefully remove the back panel from the laptop.
    • Be cautious and use wedges if needed to avoid damaging the panel.
  4. Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 4, immagine 1 di 1
    • Locate the battery in the bottom left corner.
  5. Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 5, immagine 1 di 1
    • Remove the 5 screws that secure the battery in place.
    • (Black, 3.45mm Phillips #0)
  6. Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 6, immagine 1 di 2 Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 6, immagine 2 di 2
    • Near the positive and negative symbols on the battery, you'll find a wire connected to the motherboard.
    • Gently unplug this wire.
  7. Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 7, immagine 1 di 2 Lenovo IdeaPad 330S-14IKB Battery Replacement: passo 7, immagine 2 di 2
    • There is a wire clipped to the side of the battery next to the hard drive; unhook this wire.
    • With the wire disconnected, remove the old battery.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 51
Tutti i Tempi: 215
