Salta al contenuto principale
LG G5 Battery Replacement
Cosa ti serve
  1. LG G5 Battery Replacement, Battery: passo 1, immagine 1 di 3 LG G5 Battery Replacement, Battery: passo 1, immagine 2 di 3 LG G5 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Power down the phone by holding the power button for several seconds.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Battery Replacement: passo 2, immagine 1 di 2 LG G5 Battery Replacement: passo 2, immagine 2 di 2
    • Separate the battery from bottom half.
    • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
Conclusione
Altre 21 persone hanno completato questa guida.
Sam Goldheart
Membro da: 10/18/12
465.847 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
17.182 Guide realizzate
4 Commenti
Success. Excellent guide, thank you.
Cheers,
Richard.
rmgs - Replica
Was machen wenn Akku Snap In ab ist?
Ra Ku - Replica
Hallo, was machen wenn Snap In vom Akku ab ist und Akku im Gehäuse fest sitzt?
Ra Ku - Replica
Absolutely great instructions. The battery I got for replacement comes uncharged (probably new shipping laws) so you might put in “Battery needs to be calibrated by fulling charging new battery to 100% then letting battery COMPLETELY run down to 0% before returning to normal use and charging.”
Michael Aarons - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 94
Tutti i Tempi: 15,580
