Salta al contenuto principale
Kurio Touch 4S Speaker Replacement
Cosa ti serve
  1. Kurio Touch 4S Speaker  Replacement, Speakers: passo 1, immagine 1 di 1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Speaker  Replacement: passo 2, immagine 1 di 3 Kurio Touch 4S Speaker  Replacement: passo 2, immagine 2 di 3 Kurio Touch 4S Speaker  Replacement: passo 2, immagine 3 di 3
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top; try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Speaker  Replacement: passo 3, immagine 1 di 2 Kurio Touch 4S Speaker  Replacement: passo 3, immagine 2 di 2
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
  4. Kurio Touch 4S Speaker  Replacement: passo 4, immagine 1 di 1
  5. Kurio Touch 4S Speaker  Replacement: passo 5, immagine 1 di 1
    • Gently remove the plastic cover that is covering the camera.
  6. Kurio Touch 4S Speaker  Replacement: passo 6, immagine 1 di 1
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  7. Kurio Touch 4S Speaker  Replacement: passo 7, immagine 1 di 1
    • Use the soldering tool to detach the speaker wires.
    • For more information on how to solder the wires Click here
  8. Kurio Touch 4S Speaker  Replacement: passo 8, immagine 1 di 1
    • Press the speaker in the manner shown so that it comes out of its slot.
    • Be sure not to apply too much force or you can break the back cover.
  9. Kurio Touch 4S Speaker  Replacement: passo 9, immagine 1 di 1
    • Use the Tweezers to remove the speaker from its place.
    • Remove the speaker gently.
Conclusione
Moin Khan
Membro da: 01/21/15
234 Reputazione
2 Guide realizzate
USF Tampa, Team 6-5, Brown Winter 2015 Membro di USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 160
