Salta al contenuto principale
Kodak Easyshare C813 Battery Door Replacement
Cosa ti serve
  1. Kodak Easyshare C813 Battery Door Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Kodak Easyshare C813 Battery Door Replacement: passo 2, immagine 1 di 3 Kodak Easyshare C813 Battery Door Replacement: passo 2, immagine 2 di 3 Kodak Easyshare C813 Battery Door Replacement: passo 2, immagine 3 di 3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Kodak Easyshare C813 Battery Door Replacement, Back Cover: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    Compra
  4. Kodak Easyshare C813 Battery Door Replacement: passo 4, immagine 1 di 1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Kodak Easyshare C813 Battery Door Replacement: passo 5, immagine 1 di 3 Kodak Easyshare C813 Battery Door Replacement: passo 5, immagine 2 di 3 Kodak Easyshare C813 Battery Door Replacement: passo 5, immagine 3 di 3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Kodak Easyshare C813 Battery Door Replacement: passo 6, immagine 1 di 3 Kodak Easyshare C813 Battery Door Replacement: passo 6, immagine 2 di 3 Kodak Easyshare C813 Battery Door Replacement: passo 6, immagine 3 di 3
    Phillips #00 Screwdriver
    $5.49
    Compra
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Kodak Easyshare C813 Battery Door Replacement: passo 7, immagine 1 di 3 Kodak Easyshare C813 Battery Door Replacement: passo 7, immagine 2 di 3 Kodak Easyshare C813 Battery Door Replacement: passo 7, immagine 3 di 3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Kodak Easyshare C813 Battery Door Replacement: passo 8, immagine 1 di 3 Kodak Easyshare C813 Battery Door Replacement: passo 8, immagine 2 di 3 Kodak Easyshare C813 Battery Door Replacement: passo 8, immagine 3 di 3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  9. Kodak Easyshare C813 Battery Door Replacement, Front Cover: passo 9, immagine 1 di 2 Kodak Easyshare C813 Battery Door Replacement, Front Cover: passo 9, immagine 2 di 2
    • Open the battery door.
  10. Kodak Easyshare C813 Battery Door Replacement: passo 10, immagine 1 di 3 Kodak Easyshare C813 Battery Door Replacement: passo 10, immagine 2 di 3 Kodak Easyshare C813 Battery Door Replacement: passo 10, immagine 3 di 3
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  11. Kodak Easyshare C813 Battery Door Replacement: passo 11, immagine 1 di 1
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
  12. Kodak Easyshare C813 Battery Door Replacement, Battery Door: passo 12, immagine 1 di 2 Kodak Easyshare C813 Battery Door Replacement, Battery Door: passo 12, immagine 2 di 2
    • Open the battery door by pulling in direction of arrow
  13. Kodak Easyshare C813 Battery Door Replacement: passo 13, immagine 1 di 3 Kodak Easyshare C813 Battery Door Replacement: passo 13, immagine 2 di 3 Kodak Easyshare C813 Battery Door Replacement: passo 13, immagine 3 di 3
    Heavy-Duty Spudger
    Compra
  14. Kodak Easyshare C813 Battery Door Replacement: passo 14, immagine 1 di 3 Kodak Easyshare C813 Battery Door Replacement: passo 14, immagine 2 di 3 Kodak Easyshare C813 Battery Door Replacement: passo 14, immagine 3 di 3
    • The spring is small and easy to lose
    • Carefully remove battery door and spring
    • Make spring is in correct orientation when putting back
    • The spring should hook onto a small hole in the door
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 24-22, Regan Spring 2010 Membro di Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 43
Tutti i Tempi: 12,047
