Salta al contenuto principale
HP ZBook 15 Hard Drive Replacement
Cosa ti serve
  1. HP ZBook 15 Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 HP ZBook 15 Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP ZBook 15 Hard Drive Replacement, Back Cover: passo 2, immagine 1 di 1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP ZBook 15 Hard Drive Replacement, HP ZBook 15 Hard Drive Disassembly: passo 3, immagine 1 di 1
    • Unscrew the three captive screws holding the drive in place with a Phillips #0 screwdriver.
    • The screws will remain inside the springs of the hard drive caddy cover.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP ZBook 15 Hard Drive Replacement: passo 4, immagine 1 di 2 HP ZBook 15 Hard Drive Replacement: passo 4, immagine 2 di 2
    • Pull the green tab away from the metal casing and lift the drive out.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP ZBook 15 Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 1
    • Remove the two 3mm screws on either side of the device with a Phillips #0 screwdriver to remove the drive caddy.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 13 persone hanno completato questa guida.
Grant Terris
Membro da: 01/30/15
2.888 Reputazione
12 guide realizzate
Cal Poly, Team 8-43, Amido Winter 2015 Membro di Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 Membri
19 guide realizzate
3Commenti sulla guida
You can use Macrium Reflect (there's a free non-commercial version) to backup your disk to an external drive before swapping the drive.
Paul M - Rispondi Condividi
There is written 'SSD' on its cover, and I'm confused now. Actually I need to disconnect the HDD and then install new OS on the SSD, and now I'm not sure if the drive that you just removed is SSD or HDD because on mine it say SSD. Please help me out.
Sajid - Rispondi Condividi
how hard disk i can buy for my zbook 15?
thanks
francesco perego - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 35
Ultimi 30 giorni: 147
Tutti i Tempi: 31,627
