Salta al contenuto principale
HP Pavilion x360 14-ba253cl Battery Replacement
Cosa ti serve
  1. HP Pavilion x360 14-ba253cl Battery Replacement, Keyboard: passo 1, immagine 1 di 1
    • Use the Jimmy to remove the footpads located at the bottom of the laptop.
  2. HP Pavilion x360 14-ba253cl Battery Replacement: passo 2, immagine 1 di 1
    • Remove three 4.0mm Phillips #0 screws from the top of the cover.
    • Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
    • Remove one 4.mm Phillips #0 screw beneath the divot.
  3. HP Pavilion x360 14-ba253cl Battery Replacement: passo 3, immagine 1 di 1
    • Turn the computer onto its base, with the computer open and the keys facing upward.
  4. HP Pavilion x360 14-ba253cl Battery Replacement: passo 4, immagine 1 di 1
    • Use an opening pick to separate the keyboard from the base of the laptop.
  5. HP Pavilion x360 14-ba253cl Battery Replacement: passo 5, immagine 1 di 1
    • Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
    • Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
    • Use the blue plastic tab on the ribbon cable to pull it out from the system board.
    • Remove the keyboard from the laptop.
  6. HP Pavilion x360 14-ba253cl Battery Replacement, Battery: passo 6, immagine 1 di 1
    • Remove six 3mm Phillips #00 screws around the perimeter of the battery.
  7. HP Pavilion x360 14-ba253cl Battery Replacement: passo 7, immagine 1 di 1
    • Carefully lift the battery starting from the lower right corner and disconnect it from the system board.
Conclusione
Altre 5 persone hanno completato questa guida.
Un commento
Thanks, it was useful
Oleg - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 132
Tutti i Tempi: 8,129
