Introduzione
If your HP 15-dy2024nr is not charging or not holding a charge, you may need to replace the battery. This guide will help you remove the old battery. To do this you'll first need to remove the back cover.
If the battery is swollen take extra precautions to safely remove and dispose of it. As with all parts, be sure the laptop is powered off before removing the battery.
Cosa ti serve
Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
Gently peel the feet from the laptop using the spudger revealing the screws underneath.
Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
Using another iFixit opening tool, slide along the seam to unhook the clips.
When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
After the clips have been released, flip the laptop over and lift the cover.
Remove five 2.0mm x 3.0mm screws using a Phillips #00 screwdriver.
Use the iFixit opening picks to lift the battery away from the laptop.
Altre 2 persone hanno completato questa guida.
