Salta al contenuto principale
Garmin Nuvi 255W Logic Board Replacement
Cosa ti serve
  1. Garmin Nuvi 255W Logic Board Replacement, Rear Casing: passo 1, immagine 1 di 2 Garmin Nuvi 255W Logic Board Replacement, Rear Casing: passo 1, immagine 2 di 2
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 255W Logic Board Replacement: passo 2, immagine 1 di 1
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 255W Logic Board Replacement: passo 3, immagine 1 di 2 Garmin Nuvi 255W Logic Board Replacement: passo 3, immagine 2 di 2
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 255W Logic Board Replacement, Logic Board: passo 4, immagine 1 di 1
    • Peel away the tape holding the ribbon cable in place.
    • Disconnect the ribbon cable by using a spudger to flip up the retaining flap on its ZIF-style connector. Then gently remove the cable.
  5. Garmin Nuvi 255W Logic Board Replacement: passo 5, immagine 1 di 1
    • Pull out the cable between the logic board and the speaker to disconnect them.
  6. Garmin Nuvi 255W Logic Board Replacement: passo 6, immagine 1 di 2 Garmin Nuvi 255W Logic Board Replacement: passo 6, immagine 2 di 2
    • Remove the three screws from the logic board using the #00 Phillips screwdriver.
    • Lift the board away from the case but do not pull the logic board completely off, as it is still attached to the battery by a cable.
  7. Garmin Nuvi 255W Logic Board Replacement: passo 7, immagine 1 di 2 Garmin Nuvi 255W Logic Board Replacement: passo 7, immagine 2 di 2
    • Detach the logic board form the battery by pulling out the cable.
Conclusione
Anjelica
Membro da: 04/11/10
564 Reputazione
3 Guide realizzate
Cal Poly, Team 25-90, Amido Spring 2010 Membro di Cal Poly, Team 25-90, Amido Spring 2010
CPSU-AMIDO-S10S25G90
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 26
Tutti i Tempi: 10,396
