Introduzione
The internal speaker is wired to the circuit board but not welded. If you have a replacement and the soldering skills to install it, this guide will help you identify and remove the internal speaker.
Parti
Nessuna parte richiesta.
Remove the two screws on the bottom of the device with a Phillips head screwdriver. Use a spudger to remove the plastic plate from the bottom of the player.
  • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
  • Use a spudger to remove the plastic plate from the bottom of the player.
I can't budge the inner parts from its casing
tailoredvisions - Replica
Use the spudger to push the USB port on the bottom of the device inward. Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end. The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
  • Use the spudger to push the USB port on the bottom of the device inward.
  • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
  • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
Aggiungi Commento
Identify and pull the speaker away from the device. Use a wire cutter to sever the red and black cables connecting the speaker to the circuit board.
  • Identify and pull the speaker away from the device.
  • Use a wire cutter to sever the red and black cables connecting the speaker to the circuit board.
Aggiungi Commento
Conclusione
Jesse Minor
Membro da: 15/01/2015
589 Reputazione
3 Guide realizzate
USF Tampa, Team 1-4, Tanski Winter 2015 Membro di USF Tampa, Team 1-4, Tanski Winter 2015
USFT-TANSKI-W15S1G4
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 432
