Introduzione
Remove the front cover to access the lens mount, manual and autofocus switch, lens release switch, timer light, and other components.
Parti
Nessuna parte richiesta.
Retrieve your Pentax K200D, the lens mount cover, and required tools.
  • Retrieve your Pentax K200D, the lens mount cover, and required tools.
  • Remove the lens, if you have one attached, and replace it with the lens mount cover to make handling and repair easier.
Aggiungi Commento
With the camera turned on, press the pop-up flash button to release the flash.
  • With the camera turned on, press the pop-up flash button to release the flash.
  • Be sure to turn the camera back off before proceeding.
  • Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
What if you are disassembling the camera because it wont turn on. If you cant pop up the flash is there a work around?
Sean D99 - Replica
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the seven 4.3 mm Phillips screws securing the bottom cover to the camera body
  • Remove the seven 4.3 mm Phillips screws securing the bottom cover to the camera body
  • Remove the two 2.5 mm Phillips screws also securing the bottom cover to the camera body
  • Open the battery door and carefully remove the bottom cover, as the battery door components become unsecured when the bottom cover is removed.
Aggiungi Commento
Remove the two 4.3 mm Phillips screws securing the right side of the front cover to the camera body.
  • Remove the two 4.3 mm Phillips screws securing the right side of the front cover to the camera body.
Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
Rick Nelson
Membro da: 05/06/2010
652 Reputazione
2 Guide realizzate
Master Techs Membro di Master Techs
Community
275 Membri
716 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 32
Tutti i Tempi: 3,624
