Salta al contenuto principale
Dell Inspiron 7000 2 in 1 Battery Replacement
Cosa ti serve
  1. Dell Inspiron 7000 2 in 1 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Flip your Dell Inspiron 7000 2 in 1 laptop upside down to get started. Find the locations of all the 10 screws.
    • Remember to turn the laptop off before you begin the repair.
  2. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 2, immagine 1 di 1
    • Using your Phillips #00 screwdriver, remove the ten 7.00 mm screws at the bottom of the laptop.
  3. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 3, immagine 1 di 3 Dell Inspiron 7000 2 in 1 Battery Replacement: passo 3, immagine 2 di 3 Dell Inspiron 7000 2 in 1 Battery Replacement: passo 3, immagine 3 di 3
    • Insert the spudger in the gap between the bottom cover and the frame. Then, use it as a wedge and work your way around the perimeter. This will pop open the bottom cover of the laptop.
  4. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 4, immagine 1 di 1
    • Find the battery located at the bottom right corner of the laptop.
  5. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 5, immagine 1 di 1
    • Now remove the four 4.0 mm Phillips #00 screws located at each corner of the battery.
  6. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 6, immagine 1 di 1
    • Remove the battery pin that is connecting the motherboard to the battery by pulling out the pin gently.
    • Remember to safely recycle your old laptop battery.
  7. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 7, immagine 1 di 1
    • Reinsert the battery pin into the new battery and place it back into its position.
  8. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 8, immagine 1 di 1
    • Screw the four 4.0 mm Phillips #00 head screws for the battery back into place to make sure the battery is held on securely.
  9. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 9, immagine 1 di 1
    • Place the cover back onto the laptop and press down on all corners and sides.
    • Make sure to listen for a click to ensure the cover is properly secured.
  10. Dell Inspiron 7000 2 in 1 Battery Replacement: passo 10, immagine 1 di 1
    • Use the Phillips #00 screwdriver to replace the ten 7.00 mm screws on the back cover.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Neelay Patel
Membro da: 09/17/21
234 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 42
Ultimi 30 Giorni: 179
Tutti i Tempi: 5,569
