Introduzione
Use this guide to help you replace the S-Video Board in a Dell Inspiron 1525.
Locate the battery release switch on the bottom of the laptop.
  • Locate the battery release switch on the bottom of the laptop.
Aggiungi Commento
Slide the battery release switch away from the lock symbol until you hear the battery click. Slide the battery towards the back of the laptop until it comes free.
  • Slide the battery release switch away from the lock symbol until you hear the battery click.
  • Slide the battery towards the back of the laptop until it comes free.
Aggiungi Commento
Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
Aggiungi Commento
Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up. Carefully pull the central control cover up along its edges. Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
  • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
Aggiungi Commento
Peel back the silver tape securing the ribbon cable to the cover. Pull the small brown latch on the ribbon cable connector out. Disconnect the ribbon cable to completely free the central control cover.
  • Peel back the silver tape securing the ribbon cable to the cover.
  • Pull the small brown latch on the ribbon cable connector out.
  • Disconnect the ribbon cable to completely free the central control cover.
Aggiungi Commento
Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop. Gently slide the keyboard towards the display until the tabs on its front side are free.
  • Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
  • Gently slide the keyboard towards the display until the tabs on its front side are free.
    • Do not force the keyboard too far forward or attempt to remove it yet, as there is still a ribbon cable connected to it.
Aggiungi Commento
Use a spudger to gently lift the ribbon cable retaining flap. Disconnect the ribbon cable.
  • Use a spudger to gently lift the ribbon cable retaining flap.
  • Disconnect the ribbon cable.
  • Shift the keyboard sideways enough to free one side from it's retaining tab. Then lift the keyboard away from the laptop.
the flap broke? the little black piece. Now what do i do? I'm stuck at this step
daaaammon - Replica
Remove the two 3.60 mm #1 Phillips screws securing the hard drive and hard drive tray. Slide the hard drive and hard drive tray out of the laptop. Slide the hard drive and hard drive tray out of the laptop.
  • Remove the two 3.60 mm #1 Phillips screws securing the hard drive and hard drive tray.
  • Slide the hard drive and hard drive tray out of the laptop.
Aggiungi Commento
Remove the 5.75 mm #1 Phillips screw securing the optical drive. Pull the optical drive straight from the laptop.
  • Remove the 5.75 mm #1 Phillips screw securing the optical drive.
  • Pull the optical drive straight from the laptop.
Aggiungi Commento
Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel. The screws may only need to be loosened, as they are generally retained by plastic washers.
  • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
  • Remove the bottom panel.
Aggiungi Commento
Disconnect the five antennas from their respective cards. De-route the antennas from their routing retainers. De-route the antennas from their routing retainers.
  • Disconnect the five antennas from their respective cards.
  • De-route the antennas from their routing retainers.
Aggiungi Commento
Remove the two 5.70 mm Phillips #1 screws securing the display assembly to the bottom case half.
  • Remove the two 5.70 mm Phillips #1 screws securing the display assembly to the bottom case half.
    • The screw holes will be denoted by an embossed "D" by the hole.
Aggiungi Commento
Use the flat end of a spudger to push the camera connector out of its socket. Alternate pushing on either side to evenly remove the connector. Carefully release the connector from its retaining tabs. Carefully release the connector from its retaining tabs.
  • Use the flat end of a spudger to push the camera connector out of its socket. Alternate pushing on either side to evenly remove the connector.
  • Carefully release the connector from its retaining tabs.
Aggiungi Commento
Push the antenna wires up through their hole in the bottom case half. Release the antennas from their retaining tabs on the upper case.
  • Push the antenna wires up through their hole in the bottom case half.
  • Release the antennas from their retaining tabs on the upper case.
Aggiungi Commento
Disconnect the flat LCD ribbon cable by pulling it up by the tab. Free the ribbon cable from its retaining clips.
  • Disconnect the flat LCD ribbon cable by pulling it up by the tab.
  • Free the ribbon cable from its retaining clips.
Aggiungi Commento
Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
  • Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
    • Support the display assembly as you remove these screws to prevent damage to the screw and hole threads.
  • Remove the display assembly from the laptop.
Aggiungi Commento
Remove the nine 5.75 mm Phillips #1 screws on the bottom side of the laptop. Remove the two 5.70 mm Phillips #1 screws on the top side of the laptop.
  • Remove the nine 5.75 mm Phillips #1 screws on the bottom side of the laptop.
  • Remove the two 5.70 mm Phillips #1 screws on the top side of the laptop.
Aggiungi Commento
Use a spudger to pull the touch pad connector latch towards the ribbon cable. Pull the ribbon cable out of the connector.
  • Use a spudger to pull the touch pad connector latch towards the ribbon cable.
  • Pull the ribbon cable out of the connector.
Aggiungi Commento
Use a spudger to pull the device status LED connector latch towards the ribbon cable. Disconnect the device status LED ribbon cable.
  • Use a spudger to pull the device status LED connector latch towards the ribbon cable.
  • Disconnect the device status LED ribbon cable.
Aggiungi Commento
Release the ribbon cable in the upper left corner of the laptop from its retaining tabs. Use a spudger to unplug the speaker connector at the top center of the laptop. De-route the speaker wires from their retaining tabs.
  • Release the ribbon cable in the upper left corner of the laptop from its retaining tabs.
  • Use a spudger to unplug the speaker connector at the top center of the laptop.
  • De-route the speaker wires from their retaining tabs.
Aggiungi Commento
Use the flat end of a spudger to begin lifting the upper case at its front edge. Lift the front edge of the case up until it comes free.
  • Use the flat end of a spudger to begin lifting the upper case at its front edge.
  • Lift the front edge of the case up until it comes free.
    • Work slowly and be sure not to get any cables caught in the upper case holes and guides.
Aggiungi Commento
Eject your ExpressCard or ExpressCard dust shield if you want to transfer it to the new ExpressCard cage. Eject the card by pressing it in until it clicks, releasing it, then sliding it out. Remove the 3.80 mm Phillips #1 screw securing the ExpressCard cage. Remove the two 3.70 mm Phillips #1 screws securing the ExpressCard cage.
  • Eject your ExpressCard or ExpressCard dust shield if you want to transfer it to the new ExpressCard cage. Eject the card by pressing it in until it clicks, releasing it, then sliding it out.
  • Remove the 3.80 mm Phillips #1 screw securing the ExpressCard cage.
  • Remove the two 3.70 mm Phillips #1 screws securing the ExpressCard cage.
  • Lift the ExpressCard cage out of its connector.
Aggiungi Commento
Loosen the five #1 Phillips screws securing the heat sink and clean it with compressed air These screws are attached to the heat sink assembly. Gently lift the heat sink from side indicated in the picture.
  • Loosen the five #1 Phillips screws securing the heat sink and clean it with compressed air
    • These screws are attached to the heat sink assembly.
  • Gently lift the heat sink from side indicated in the picture.
    • The heat sink may feel like it is glued to the chips because of the thermal paste. Gently wiggle the heat sink back and forth to help break it free.
  • Be sure to thoroughly clean off the old thermal paste and apply new thermal paste before reinstalling the heat sink. Follow our thermal paste application guide for detailed instructions.
Aggiungi Commento
Use a spudger to push the retaining latch of the central control button connector towards its cable. Pull the cable out of the connector.
  • Use a spudger to push the retaining latch of the central control button connector towards its cable.
  • Pull the cable out of the connector.
Aggiungi Commento
Pull the retaining latch for the wireless sniffer cable out. Remove the cable from the connector.
  • Pull the retaining latch for the wireless sniffer cable out.
  • Remove the cable from the connector.
Aggiungi Commento
Disconnect the fan cable connector by pulling it towards the fan with a spudger. Disconnect the fan cable connector by pulling it towards the fan with a spudger.
  • Disconnect the fan cable connector by pulling it towards the fan with a spudger.
Aggiungi Commento
Remove the four 3.70 mm Phillips #1 screws securing the motherboard to the lower case. Gently peel the front bezel off. Lift the motherboard out of the lower case.
  • Remove the four 3.70 mm Phillips #1 screws securing the motherboard to the lower case.
  • Gently peel the front bezel off.
  • Lift the motherboard out of the lower case.
  • If you are installing a new motherboard, make sure to transfer any remaining cables onto the new motherboard, as well as the CPU, RAM, modem, and Wi-Fi card.
Aggiungi Commento
Remove the two 5.65 mm Phillips #1 screws securing the S-Video board to the lower case. Remove the S-Video board.
  • Remove the two 5.65 mm Phillips #1 screws securing the S-Video board to the lower case.
  • Remove the S-Video board.
Aggiungi Commento
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,451
