Salta al contenuto principale
Dell Inspiron 13-7352 System Board Replacement
Cosa ti serve
  1. Dell Inspiron 13-7352 System Board Replacement, Battery: passo 1, immagine 1 di 3 Dell Inspiron 13-7352 System Board Replacement, Battery: passo 1, immagine 2 di 3 Dell Inspiron 13-7352 System Board Replacement, Battery: passo 1, immagine 3 di 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 System Board Replacement: passo 2, immagine 1 di 2 Dell Inspiron 13-7352 System Board Replacement: passo 2, immagine 2 di 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 System Board Replacement: passo 3, immagine 1 di 1
    • Gently remove the battery from the rest of the device.
  4. Attenzione: i passaggi 4-5 provengono da una guida contrassegnata come in corso.
    Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): passo 4, immagine 1 di 3 Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): passo 4, immagine 2 di 3 Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): passo 4, immagine 3 di 3
    • Locate your memory module (RAM).
    • Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
  5. Dell Inspiron 13-7352 System Board Replacement: passo 5, immagine 1 di 1
    • Pull the Memory Module from its slot by grasping each side with thumb and middle or index finger to pull from the rest of the device.
  6. Dell Inspiron 13-7352 System Board Replacement, System Board: passo 6, immagine 1 di 3 Dell Inspiron 13-7352 System Board Replacement, System Board: passo 6, immagine 2 di 3 Dell Inspiron 13-7352 System Board Replacement, System Board: passo 6, immagine 3 di 3
    • Remove cord that runs from system board to the I/O board.
    • Remove connecting wire that runs from fan to system board.
  7. Dell Inspiron 13-7352 System Board Replacement: passo 7, immagine 1 di 1
    • Remove the 3mm and 4mm screws using the Phillips #0 head for both that hold down the fan
  8. Dell Inspiron 13-7352 System Board Replacement: passo 8, immagine 1 di 1
    • Lift the fan from the system board by using your thumb and index or middle finger to gently pull away from the rest of the device.
  9. Dell Inspiron 13-7352 System Board Replacement: passo 9, immagine 1 di 3 Dell Inspiron 13-7352 System Board Replacement: passo 9, immagine 2 di 3 Dell Inspiron 13-7352 System Board Replacement: passo 9, immagine 3 di 3
    • Remove the three 4mm screws with the Phillips #0 holding down the heat sink.
    • Remove the two 4mm screws with the Phillips #0 holding down the metal bracket.
    • Unscrew the single 3mm screw using the Phillips #0 head securing the system board.
  10. Dell Inspiron 13-7352 System Board Replacement: passo 10, immagine 1 di 2 Dell Inspiron 13-7352 System Board Replacement: passo 10, immagine 2 di 2
    • Remove the wire connections attached to the system board.
    • Remove the tape wires from the system board.
  11. Dell Inspiron 13-7352 System Board Replacement: passo 11, immagine 1 di 1
    • Carefully remove the system board from the base by grasping with thumb and index or middle finger and pulling away from the rest of the device.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,814
