Salta al contenuto principale
Casio CTK-501 Battery Connection Replacement
Cosa ti serve
  1. Casio CTK-501 Battery Connection Replacement, Bottom Panel: passo 1, immagine 1 di 2 Casio CTK-501 Battery Connection Replacement, Bottom Panel: passo 1, immagine 2 di 2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Battery Connection Replacement: passo 2, immagine 1 di 1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Battery Connection Replacement: passo 3, immagine 1 di 2 Casio CTK-501 Battery Connection Replacement: passo 3, immagine 2 di 2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Battery Connection Replacement, Battery Connection: passo 4, immagine 1 di 1
    • Plug in the soldering iron.
    • Set the soldering iron somewhere safe, where it can't catch anything on fire.
    • Unscrew the top green circuit board with black and red wires running through it.
  5. Casio CTK-501 Battery Connection Replacement: passo 5, immagine 1 di 1
    • Set the circuit board somewhere flat so it is safe to solder.
  6. Casio CTK-501 Battery Connection Replacement: passo 6, immagine 1 di 1
    • Heat up the solder covering the end of the wires connected to the circuit board.
    • Once the solder melts, remove the wires from the circuit board.
  7. Casio CTK-501 Battery Connection Replacement: passo 7, immagine 1 di 1
    • Melt new solder with your soldering iron.
    • Then apply it over the tip of the wire resting on the circuit board.
  8. Casio CTK-501 Battery Connection Replacement: passo 8, immagine 1 di 1
    • Once the wires are firmly attached, screw the circuit board back into the keyboard.
Conclusione
Altre 3 persone hanno completato questa guida.
Jimmy Winne
Membro da: 10/04/12
578 Reputazione
6 Guide realizzate
Cal Poly, Team 9-16, Amido Fall 2012 Membro di Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 26
Tutti i Tempi: 4,752
