Introduzione
This guide will go over how to replace the switches on a CM Quickfire Rapid keyboard.
Remove the keycap of the key whose switch you'd like to replace by following the small keycap replacement guide or large keycap replacement guide. Remove the keycap of the key whose switch you'd like to replace by following the small keycap replacement guide or large keycap replacement guide.
Aggiungi Commento
Using a Philips #0 screwdriver, remove the .5cm screw from the back of the keyboard. This will void your warranty!
  • Using a Philips #0 screwdriver, remove the .5cm screw from the back of the keyboard.
  • This will void your warranty!
  • When inserting the screw after replacing the switch, make sure to not screw in too tight. This may cause erratic behavior with the keyboard.
Aggiungi Commento
Wedge a plastic opening tool between the rear plate and rim of the keyboard and slide it through the circled areas to separate the plastic hooks that mount the rim to the rear plate. Wedge a plastic opening tool between the rear plate and rim of the keyboard and slide it through the circled areas to separate the plastic hooks that mount the rim to the rear plate. Wedge a plastic opening tool between the rear plate and rim of the keyboard and slide it through the circled areas to separate the plastic hooks that mount the rim to the rear plate.
  • Wedge a plastic opening tool between the rear plate and rim of the keyboard and slide it through the circled areas to separate the plastic hooks that mount the rim to the rear plate.
Aggiungi Commento
Firmly grasp the bottom panel of the keyboard and carefully detach it from the rest of the board. Do not put strain on the ribbon cable when lifting the bottom panel.
  • Firmly grasp the bottom panel of the keyboard and carefully detach it from the rest of the board.
  • Do not put strain on the ribbon cable when lifting the bottom panel.
Aggiungi Commento
Detach the 4-pin cable from the bottom panel of the keyboard. Detach the 4-pin cable from the bottom panel of the keyboard.
  • Detach the 4-pin cable from the bottom panel of the keyboard.
Aggiungi Commento
Desolder the joints holding the switch to the board.
  • Desolder the joints holding the switch to the board.
  • Remove the switch and solder the new switch in place.
how to know witch joints to Desolder
Dominique Dubbeldam - Replica
Conclusione
Altre 6 persone hanno completato questa guida.
Andrew
Membro da: 12/10/2014
285 Reputazione
2 Guide realizzate
Cal Poly, Team 6-23, Maness Fall 2014 Membro di Cal Poly, Team 6-23, Maness Fall 2014
CPSU-MANESS-F14S6G23
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 145
Tutti i Tempi: 7,335
