Salta al contenuto principale
Behringer Eurolive B212D Power PCB Replacement
Cosa ti serve
  1. Behringer Eurolive B212D Power PCB Replacement, Removing the Behringer Eurolive B212D Electronics Box: passo 1, immagine 1 di 1
    • CAUTION: Unplug your speaker from the power outlet.
    • Remove the 8 Phillips screws from the back of the speaker.
  2. Behringer Eurolive B212D Power PCB Replacement: passo 2, immagine 1 di 1
    • Carefully remove the back panel, lifting out the metal electronics-box with it.
    • To avoid damaging your speaker, remove slowly, as there is still a wire attached from the electronics box to the speaker.
  3. Behringer Eurolive B212D Power PCB Replacement, Detach the Behringer Eurolive B212D Electronics Box: passo 3, immagine 1 di 3 Behringer Eurolive B212D Power PCB Replacement, Detach the Behringer Eurolive B212D Electronics Box: passo 3, immagine 2 di 3 Behringer Eurolive B212D Power PCB Replacement, Detach the Behringer Eurolive B212D Electronics Box: passo 3, immagine 3 di 3
    • There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
    • There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
    • You should have removed a total of 7 machine screws and 2 washers.
    • The reason for removing the two screws with the two washers first (or replacing them last when reassembling) is that their holes are actually slots. They are designed as slots to accommodate slop in the assembly, and if unscrewed out of order, you may have difficulty while removing - or possibly even damage - the other five screws.
  4. Behringer Eurolive B212D Power PCB Replacement: passo 4, immagine 1 di 1
    • Remove the portion of the metal housing that you freed with the 7 screws in the previous step.
  5. Behringer Eurolive B212D Power PCB Replacement: passo 5, immagine 1 di 3 Behringer Eurolive B212D Power PCB Replacement: passo 5, immagine 2 di 3 Behringer Eurolive B212D Power PCB Replacement: passo 5, immagine 3 di 3
    • Inside the metal electronics box housing is a white clip attached to a small PCB; remove this.
    • The white clip in this image has been glued, indicating that the manufacturer may not expect the end user to remove this clip; it is difficult to proceed with the disassembling without doing so, however, because the rest of the speaker does not provide a sufficient surface on which to work.
    • Snake the clip head through the hole in the metal electronics box casing.
  6. Behringer Eurolive B212D Power PCB Replacement, Disassembling Behringer Eurolive B212D Power & Control Panel: passo 6, immagine 1 di 2 Behringer Eurolive B212D Power PCB Replacement, Disassembling Behringer Eurolive B212D Power & Control Panel: passo 6, immagine 2 di 2
    • Remove the 4, 7/32" long machine screws with a #2 phillips head screwdriver.
  7. Behringer Eurolive B212D Power PCB Replacement: passo 7, immagine 1 di 2 Behringer Eurolive B212D Power PCB Replacement: passo 7, immagine 2 di 2
    • Caution: The circuit board contains many capacitors that could cause serious injury if touched. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Rotate the back panel so you can view the interior; note the three wires attached.
    • Remove the wires to you can fully remove the back panel.
  8. Behringer Eurolive B212D Power PCB Replacement, Power PCB: passo 8, immagine 1 di 3 Behringer Eurolive B212D Power PCB Replacement, Power PCB: passo 8, immagine 2 di 3 Behringer Eurolive B212D Power PCB Replacement, Power PCB: passo 8, immagine 3 di 3
    • Remove the 4 indicated 7/32" long machine screws with a #1 phillips head screwdriver.
    • Remove the box containing the power PCB.
  9. Behringer Eurolive B212D Power PCB Replacement: passo 9, immagine 1 di 2 Behringer Eurolive B212D Power PCB Replacement: passo 9, immagine 2 di 2
    • There are 4 remaining 7/32" long machine screws holding the power PCB to the box which contains it; remove these with a #1 phillips head screwdriver.
    • Remove the power PCB.
Conclusione
Altre 6 persone hanno completato questa guida.
Troy W. Weber
Membro da: 03/29/12
1.431 Reputazione
6 Guide realizzate
13 Commenti
This PCB does not convert electricity, and is rarely what fails. AC leaves this board and gets converted to DC at the rectifier bridge, which is part of the main amp PCB. This main amp board is where 99.9% of issues arise...
Gabriel Talamantes - Replica
Do you know where I can find replacement boards for this speaker? It takes about 20 times of cycling the power button for it to finally come on. Can't seem to find parts anywhere. May not be financially smart to replace the board, but if it's not that expensive, I feel it's worth it.
Justin -
Hi. Why dont you fix the board?
riaandd - Replica
Has anyone got a circuit diagram for the power board. Is it a switch mode power supply - the power plug indicates 240V or 110 V AC which would normally indicate it uses a switch mode power supply at the front end
Jonathon - Replica
my fuse holder the plastic broke because there is not enough pressure to hold in the fuse and turns on and off
Jeffrey Martinez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 45
Ultimi 30 Giorni: 141
Tutti i Tempi: 19,316
